Disposal Of IC225s
RichmondCommu
23 Feb 2010
Richmond, London
G'day everyone,
Assuming that Virgin takes delivery of it's new class 800s / 801s on time in December 2018 can we expect to see the first IC225s going for scrap in early 2019?
From what I understand Virgin would like to retain half a dozen sets for relief work etc so can we expect them to retain the trains with the lowest mileage / best condition?
Your thoughts would be very welcome!
Kind regards,
Richmond Commuter!
WatcherZero
25 Feb 2010
I understand they were going to make a decision closer to the time over how much to keep and what additional services would be viable to operate.
Flying Snail
12 Dec 2006
G'day everyone,
I doubt that will happen.
What possible use they may have is unclear at present; open access, MML, other electrified lines with 90/91/new build electric or even diesel P-P. They could be broken up into shorter sets with Mk3 DVTs added if needed.
Of course it's possible they won't find a home but I doubt the ROSCO will be in a hurry to scrap them, look at some of the other stuff that has gone into storage for expended periods.
RichmondCommu
23 Feb 2010
Richmond, London
I'm assuming that won't amount to much or else they would just order more trains from Hitachi? Which will surely have to be the medium to long term solution?
Assuming that the ECML is pretty much full up (especially south of Peterborough) surely they would only be looking to save around six trains from the scrap yard?
Why would IC225s be chosen over EMU's for the MML? Surely if there was a future for the IC225s they would have gone to the Norwich route?
The Ham
6 Jul 2012
How about LM taking them to run the longer distance services, such as London to Crewe?
A shortened rake (say loco, 6 coaches and DVT) should be able to keep to the timings of an 110mph EMU given the relatively few stations it will serve, whilst giving a noticeable increase in capacity.
168lover
2 Aug 2013
Chiltern Mailine Land
They're being used to haul the 442's to & from Manchester airport ... or something ...
Wasn't the intention once to use them for freight when not hauling passenger services? 86 replacement maybe?
No they're having 3rd rail shoes fitted so that they can haul 442sinto Brighton on Cross Country services silly :)
Doubt it could ever match the dwell times.
jopsuk
13 May 2008
I'm still surprised the IEP contract hasn't had a variation to gain another half a dozen 5-car class 801 for the EC to cover for the half dozen shortened sets.
D365
29 Jun 2012
I believe it was because VT/EC couldn't come to an agreement with Agility Trains/DfT. Wait and see though.
Domh245
6 Apr 2013
nowhere
Are end doors so much slower that when there's 50% more if them they are still slower?
The problem is that from each door, you can only go in one direction, for 11.5m, stopping to let people sit down/load overhead luggage etc. With a more conventional layout, you can go in two directions from each door and then for a shorter length (I would say about 5m in each direction) so boarding will be quicker. It isn't just about the number of doors but about the throughput of each door.
And besides, we all know that passengers only ever use two doors of a train at most! :D
CosherB
23 Feb 2007
Northwich
I'd be, frankly, amazed if the Mk4 carriages are scrapped. I don't see much of a future for the 91s but the rolling stock has plenty of life left in it. 300ish 125mph carriages with plug doors, CET and recently refurbished anyone?
I would expect all the users of Mk3s would be likely to replace them with Mk4s for precisely those kinds of feature.
The 91s are done for in my opinion. Everything would seem to suggest that they're worn out after hard decades of powering up and down the ECML. The Mk4s on the other hand I can see having a future beyond the ECML.
Flying Snail
12 Dec 2006
Certainly ATW, perhaps Scotrail on LHCS services?
Scotrail are committed to taking the HSTs though.
I suppose if the timing lined up there would have been the possibility of converting the electrics to use Mk4s with HST powercars, I imagine it would be a cheaper mod than the work needed on the Mk3s by a long way.
ATW will no doubt be angling for DMU replacement for the Manchester LH set and the Gerald nonsense cannot go on forever.
DPWH
8 Sep 2016
There may be work for them on the Scottish sleepers; that releases 92s for export to Bulgaria. I'm struggling to think of other possible duties however.
D365
29 Jun 2012
Bearing in mind that GBRf have been trying to get on top of teething issues, I don't think they'll be willing to go through that again. Especially considering it would be a downgrade to an older and more outdated locomotive.
But what about the Fife Loco Hauled? Mk4s might be a good stop-gap until the Fife Circle is wired.
92s are needed for their ETS, I doubt that a 91 can match it as the 92s were designed specifically to provide a huge amount of ETS for the Nightstar stock. Even if the 91s can supply the ETS I'm not sure it would be wise to put that sort of strain on them at this point in their life.
TheEdge
29 Nov 2012
Norwich
I think they were designed so they could haul express freights like TPOs when not needed for passenger service. However they are in no way designed for low speed heavy freights. That the re-occurring issue with all redistribution plans for the 91s is they are the last generation of East Coast thoroughbreds. They are locos designed for long distance high speed running with minimal stops. Lots of the suggestions like the MML or GEML would see them struggle with the regular stops and lower speeds. It can be seen to a certain extent with the 90s on the GEML.
G'day everyone,
The first tranche of VTEC IEPs is to replace their HSTs (bi-modes).
The second tranche (electric) replaces the 225s.
