Disruption around Retford due to signal failure (17/02/19)
jyte
27 Oct 2016
in me shed
Signal failure. Better or worse than downed overhead wires?
Edit: Title should be 'signalling system failure'. If a mod wants to edit. Both lines blocked.
_toommm_
8 Jul 2017
Signal Failure definitely worse if it's the whole system in the area - if it's just an overhead wire failure, depending on where the 91s come to a stop, the HSTs and 180s can still operate to some capacity - signal failure stops everything
jyte
27 Oct 2016
in me shed
Have to agree. I'm watching the trains 'move' on Opentraintimes now...and they're not really moving. My train is now 50 mins late.
_toommm_
8 Jul 2017
Let's just say I'm glad I chose a North Country Rover and not a North East Rover this week...
jyte
27 Oct 2016
in me shed
I've been sat outside of Retford for just over an hour so far....
Me too!
Trains are going through the block now, but at an absolute walking pace. The first one was 109 minutes late, the two next trains to go through will both be over two hours late.
Still no information as to what's actually happened beyond 'signalling system failure'.
221129
21 Mar 2011
Sunny Scotland
Me too!
Which train are you on? All trains back to a stand while the my try again to switch Retford Remote Panel back in.
Highlandspring
14 Oct 2017
Never heard this before, is it an interlocking issue?
So “information as to what’s actually happened” hasn’t enlightened you in any way. Is it surprising, then, that it isn’t announced to the public?
jyte
27 Oct 2016
in me shed
Perhaps 'the public' would do better if people like you actually bothered to explain issues rather than just get irrationally angry when people ask questions and ask for explanations?
I may not be in the industry, but I've participated in, enjoyed and benefited these forums for about 3 years now. Some here actually care and try and explain things, others don't.
dosxuk
2 Jan 2011
So you're expecting conductors / station staff to be able to provide in depth technical information as to the nature of a problem in language that the man-on-the-street would be able to understand?
jyte
27 Oct 2016
in me shed
Well, I apologise if people feel I'm being rude for asking for more information about a railway related problem on a rail related forum when I didn't understand the initial three word response.
221129
21 Mar 2011
Sunny Scotland
No but some One on a specialist rail forum could be a bit more helpful than a 3 word response that means nothing to most people.
10 Oct 2013
In a nutshell, a small signalling fault led to the override system being used. The override system at Retford would normally set routes through the platform lines automatically without any input from the signaller. It failed to do this and locked the panel up. The remote panel, which is a copy of the signallers panel but directly connected to the interlocking in the relay room, was then switched in but itself failed. Signalling was eventually restored when S&T worked to switch the remote panel in.
I personally don't have any problem with people asking for the information. The problem I have is when people are told the information and then draw the wrong conclusions. For this reason and for the sake of simplicity I have deliberated removed certain key phrases and processes in the above description.
Highlandspring
14 Oct 2017
I’m not angry; it’s just that in this instance the explanation of what’s actually happened would necessarily have to be so convoluted that it really is better just to announce “a signalling system failure”. But I’ll try anyway...
[BING BONG]
Ladies and Gentlemen..
In the signalbox at Doncaster, the signallers use a large physical control board called a ‘panel’ to control the signals and points. Earlier this morning a button on the panel which is used to set routes between signals in the Retford area broke. Because of the way the signalling interlocking works this then prevented any other routes in the area from being set and all the signals in the Redford area were stuck at red, so all the trains had to stop. This is because the safety of the entire railway system is predicated on the idea that trains stop at red signals and normally the default state for a signal is to show its most restrictive aspect, although this isn’t by any means always the case for various reasons. An ‘aspect’ by the way is what the railway calls the colour of light a signal shows, a bit like traffic lights on roads.
Luckily in case something like this happens there’s a system in place to ‘override’ the usual electronic link between the signalbox and the remote interlocking at Retford. This system would cause the signals to operate automatically without needing to communicate with the signalbox in Doncaster but it also means not all routes between signals would be useable, for a variety of complicated reasons. This is called the Override system. This morning the signaller attempted to switch in the Override as per his operating procedures but this didn’t work. It turns out this was because of a sticky relay in the interlocking. The failure of the Override to work meant that all the signals stayed at red.
In case something like this happens, there’s also a “remote panel” in the relay room at Retford. This is quite similar the signaller’s panel in Doncaster but it only controls the signals in the Retford area and is only used in an emergency when - for whatever reason - the electronic link between the signalbox and the relay room isn’t working or it’s necessary to switch it off. The relay room, by the way, is the building which houses all the relays and wires which make up the remote interlocking. There’s also an interlocking in the signalbox at Doncaster which deals with the interface between the various remote interlockings and the signaller’s panel and that’s what went wrong this morning when the button broke but don’t worry too much about that now. Anyway, because it’s physically located in Retford the panel has to be operated locally by staff who have to drive to site. Today once those staff arrived at the relay room it so happened that the remote panel also couldn’t be switched in when they tried because of the same sticky relay which was stopping the Override being switched in, although no one knew that at the time. This meant that the signals were still stuck on red. Technicians who specialise in this sort of thing were called to see if they could find out why the Override and remote panel weren’t working. Once the technicians traced the fault and fixed the sticky relay, the staff who were on site to operate the remote panel were able to switch it in successfully.
However, by the time all this happened the railway had already implemented a degraded mode of operation called “Emergency Special Working” which allows train drivers to pass red signals under very carefully managed conditions to ensure they can move safety without the risk of colliding with each other. Because this method of operation had already been set up and trains were passing through the area, albeit at reduced speed, trains again had to be stopped and Emergency Special Working cancelled in order to safely being the remote panel into operation, again to eliminate the risk of having two trains collide.
And that, ladies and gentlemen, is why your train is late.
DerekC
26 Oct 2015
Hampshire (nearly a Hog)
Thanks, Highlandspring. That's very helpful and clear. And it is useful because quite a lot of people on this forum will understand what you are talking about and can help to explain to others that the industry isn't as incompetent as they tend to assume.
dosxuk
2 Jan 2011
The original issue was that someone on the train hadn't been told anything more than it was a "signalling system failure". No amount of explanation here would correct what that poster saw as insufficient information being supplied to passengers.
PHILIPE
14 Nov 2011
Caerphilly
Off topic, but on Friday a TfW service suffered a fire which, through public Media sources, the whole world and his dog knew about it but NRE and TFW just stated "Operational Incident"
jyte
27 Oct 2016
in me shed
Sincere thanks to dwaynedibleyuk and Highlandspring.
Apologies for the grumpiness, probably has something in common with being stuck on a stationary train for two hours :)
