Do other manufacturers besides Stadler offer platform level boarding?
Philip Phlopp
31 May 2015
Crossrail will have level boarding in the core section, but not in the western and eastern sections as they are, for some unknown reason, built higher than the standard platform height
No, platform height on the western section averages 850mm, the eastern section averages 1000mm. There are some platforms on the western section which have been increased to 1100mm for Heathrow Express service.
Alex27
11 Mar 2020
Oxford
Which is what I don't understand, as there is a standard platform height why has it not been consistently used? Surely crossrail was an excellent opportunity to standardise the platforms as much as possible (/idealistic teenage rant)
Philip Phlopp
31 May 2015
There's gauging issues on both east and west sections which limit what can be done - not just freight, but high speed passenger services needs a little more space (the dynamic gauge).
Alex27
11 Mar 2020
Oxford
True, true, I suppose I wish this stuff was just done, no matter the cost, to help create a better and more equal railway and society, but money talks and I'm way too idealistic for my own good
rebmcr
15 Nov 2011
St Neots
Yes but old platforms aren't all that height and there are places where changing it would be prohibitively impractical, such as busy interchanges with buildings on the platforms.
It's a stretch to call that prohibitive. Expensive and difficult in places, yes — but that's no reason to dismiss the entire concept.
James James
29 Jan 2018
Other countries have managed it. (Not 100% completed of course, but done in such a way that the vast majority of passengers get level boarding.)
Mikey C
11 Feb 2013
Maybe we should shut down some of the uneconomic lines, and cancel HS2 to help pay for level boarding on the rest of the network...
rebmcr
15 Nov 2011
St Neots
Have you calculated the relative costs of those, or are you just naming extremes as hyperbole?
AlexNL
19 Dec 2014
The Dutch Railways are currently working on a rolling programme to bring the platforms from the legacy standard (84cm above top of rail) to the TSI standard: 76cm above top of rail. They do this by either rebuilding platforms, or raising the track in places where it's not possible to change the platform.
There's little stopping the UK from doing the same (especially in places where OLE is not a factor), except for money of course.
trebor79
8 Mar 2018
If you lower the floor for most of the vehicle then the 2 floor heights reduces capacity and flexibility for the internal layout. Most other manufactures have gone for the wide walk through corridor connections to reduce crush loading issues in peak. Ramp deployment also increase dwell times and has the risk that they won't retract.
Have you been on a 745 or 755? The floor layout in no way reduces capacity of these units, and there is a wide connection between vehicles, except for the 755 power unit and the electrical gubbins in the middle of a 745 (and even then there is a large, windowless area where the two half-units are coupled together.
As the coach tapers in more than a normal one I don't think you could do 3+2 in a low floor body, but to be fair I don't think you should be doing 3+2 anyway, the Class 700 approach of narrower 2+2 with lots of circulation space works better.
Domh245
6 Apr 2013
nowhere
A low floor does compromise capacity, it's a simple fact, the GA FLIRTs however aren't designed to be high capacity units and so it doesn't really impact them.
Lower floors mean narrower bodies (for a given vehicle length), 2+3 seating in a FLIRT would be impossible, whilst being merely uncomfortable in something like an Aventra. The ramps/steps up and down limit what can be done with the seating arrangement, the high floor sections in the FLIRTs have table bays, continued airline seating doesn't look like it'd work above them although granted that is conjecture and would depend on the seating throughout the rest of the unit - it does however make it an awful lot more complicated to fit seats in than if you just have one flat floor. Similarly, the low floor means that you loose vehicle length to accommodate the traction equipment - not so much of an issue in rural Anglia or London-Norwich, but somewhere like the Waterloo Suburban lines where you need all 200m of train to be passenger accommodation or driver's cab it is an issue.
I would also point out that whilst the FLIRTs are walk through, they are by no means 'wide' connections between the vehicles, at floor level they are 'corridor' width - compare that with something like an Aventra which is considerably wider at floor level - you could quite happily stand multiple people in an Aventra or Desiro City gangway, not so in a FLIRT.
trebor79
8 Mar 2018
Some of the raised sections in the 755's have airline seating. The raised sections really don't make that much of a difference. I tend to like sitting in the raised section, but that's about as far as it goes.
I take your point about the power pack in the 755's, but like you say it's not an issue on the routes they were built for, or many routes for that matter. The 745s are effectively two EMU's permanently coupled and with the inner cabs removed. I guess it's just easier to remove the cab and leave an empty space rather than start modifying bodyshells etc for a one off order. I don't think there's any fundamental reason that there has to be a short section of empty space in the middle of them.
trebor79
8 Mar 2018
Yes they are narrower at floor level. That pushes the heating duct toward your feet and combined with the pretty beefy seat cantilever support make the airline window seats the least desirable on the train, in my view.
You don't, of course, have to use cantilever seats, and indeed I find them a very poor design as it decreases passenger comfort to save the cleaners' time, which is a poor choice of priorities.
Best is to bolt the seat to the sidewall and to the floor in one place at the outer edge.
trebor79
8 Mar 2018
I quite like the cantilever seats actually, it leaves plenty of room for luggage under the seats and if it makes it easier to keep clean then that's good too. The leg bolted to the floor designs always end up looking tatty and grubby as it's just not practical to clean right into the crevices on a regular basis.
Overall I think they are very good units and clearly a lot of thought has gone into the layout and seating. I think they've done very well to get level boarding and made the compromises that entails almost unnoticable.
Domh245
6 Apr 2013
nowhere
Far as I can tell, those raised airline sections aren't at a normal seat pitch though, which is why they might be seen as a 'compromise' - particularly for the pack-em-in approach to train interiors.
Seats/metre of train may not be critical on many routes, but it is critical on many others, including most of the busy London suburban routes where level access would arguably be most beneficial. As for the 745s, it certainly wouldn't be out of character for Stadler to modify the bodyshell to save the space if they could. There'll be some sort of equipment in there, otherwise they'd have pushed the partition wall further back!
Mikey C
11 Feb 2013
I was using those as extreme examples to point out that the railway has tough choices, and a limited budget. If you devote vast sums towards raising every platform, that money has to come from somewhere
In reality if you buy the trains now you can do the platforms on an ongoing, bit by bit basis. That's how SBB did it.
py_megapixel
5 Nov 2018
Northern England
A logical time to do it is probably when some other major work is going on at the station. For example, if you're doing a platform extension then I assume you could build the extension to the new height, then close the old bit of the platform to be rebuilt while the extension is used to stop trains.
Indeed. In the meantime you've still got an advantage of the step up being smaller than other stock and the gap at least partially being bridged.
Philip Phlopp
31 May 2015
...I assume you could build the extension to the new height, then close the old bit of the platform to be rebuilt while the extension is used to stop trains.
It's unlikely. The majority of platform extensions are short lengths, in Scotland at the moment there's some work going on to look at how the current 120m capable (6 x 20m) platforms can be extended to 161m/184m capable (7/8 x 23m). The platform extensions will be around 41m/64m which isn't enough length to stop a service at, even with SDO, whilst the rest of the platform is modified.
That also assumes that the position of the platform extension allows a train to stop without fouling any pointwork, or that there's no issues with platform starter signals, signalling systems or DOO apparatus that requires rolling stock to be at a specific position for detection, signal visibility, DOO monitor alignment etc.
Robertj21a
22 Sep 2013
I think it would be worth having a look at the campaign for level boarding's website: https://www.levelboarding.org.uk I personally think level boarding should be mandatory on all new trains (Or at least part of the train) to make the life's of disabled passengers, and indeed everyone else's, better. There is a standard platform height, which all new platforms are built too (730mm by 915mm). Yes this is a big undertaking, but a very necessary one in my opinion.
Totally agree. On occasions there seems to be a strange reluctance to make the necessary effort to accommodate those with disabilities.
Robertj21a
22 Sep 2013
Fair comment but it often appears that disability issues are placed rather far down any list of priorities.
