Do you consider air travel to be comfortable?
Discussion in 'Other Public Transport' started by CanalWalker, 13 May 2019.
  1. CanalWalker
    CanalWalker On Moderation
    42
    13 May 2019
    Moderator note: moved from https://www.railforums.co.uk/threads/manchester-euston-£320-ret.182476/page-3
    Air travel without discomfort? I wish!
    Rail Forums
  3. Bletchleyite
    Bletchleyite Veteran Member
    38,042
    Up and down the south WCML (mostly)
    I believe it's called "business class", though it will cause you some discomfort of the wallet, I suppose.
  4. CanalWalker
    42
    13 May 2019
    Business class shares the same low air pressure and smoking ban as steerage.
  5. Bletchleyite
    38,042
    Have a try of a 787, which has a higher cabin pressure and humidity than most other aircraft. It really does make a difference. I don't do sleeping on planes, but for a 7 hour day flight it made a huge difference to my (lack of) grogginess on arrival compared with the 777-300ER on the way out.
    Difficult to avoid that without the whole thing reeking of fag ash. Patches are probably the way to go.
  6. yorkie
    yorkie Administrator Staff Member Administrator
    41,582
    I find it bizarre and difficult to comprehend that anyone would consider a smoking ban to be causing discomfort!
  7. Bletchleyite
    38,042
    Now we've got a dedicated thread...I also find journeys in the exit row on sleasyJet when there's nobody in the middle to be an entirely pleasant experience. And if there's going to be a middle seat free, it's that one - who would pay extra to be sat between two rugby player sized blokes unless travelling as a two, and if you are it can be worth booking window and aisle and hoping nobody goes for middle[1] as a result?
    [1] If they do, just offer them the choice of window or aisle as a swap - almost nobody will ever turn that down.
  8. hexagon789
    hexagon789 Established Member
    4,493
    2 Sep 2016
    Not if they are a smoker perhaps? ;)
  9. Bletchleyite
    38,042
    Most smokers don't want to be sat in a room (aluminium tube) full of old fug, though, do they? In the days of the smoking carriage it tended to be that people would go there for a smoke and return elsewhere, which meant a guaranteed seat in there for anyone who didn't mind putting up with it in preference to standing in the vestibule on ICWC services in the 1990s.
    Just get some patches for the journey - it's better for everyone that it's banned, really. It also reduces the fire risk.
  10. hexagon789
    4,493
    2 Sep 2016
    Hence why I said "perhaps". I know that plenty of smokers may not necessarily like the "fug".
  11. Bletchleyite
    38,042
    Other than in Germany in the 1990s, where opening the window was "streng verboten" even if the fug was so thick you couldn't see and the temperature was 40 degrees.
  12. Struner
    Struner Member
    133
    13 Dec 2018
    Ommelanden, EU
    wear sandals or slippers when checking in & put your shoes/boots in your (hand-)luggage lol
    it's way more boring than travelling by train
  13. hexagon789
    4,493
    2 Sep 2016
    Thank God for smoking bans o_O
  14. paddington
    paddington Member
    664
    19 Feb 2013
    The annoying thing about smoking bans is that you now have to pass through a cloud of smoke when walking into many buildings. At hospitals in particular, the preferred place for smokers seems to be in front of the NO SMOKING signs by the entrances.
    This is a problem at the Heathrow T4 and T5 bus stops, though smokers at the central bus station seem to respect the signs and indulge in their habit by the shortcut passage between the arrival bus stop to the toilets/escalators.
    Another side effect of the smoking ban relating to air travel is that the only way for people connecting at Heathrow (or other UK airports which are less used for connections) to smoke between their flights is to go landside, while at other airports in the world there are smoking rooms inside the airport. If not connecting to/from domestic or to Ireland flights, this clogs up the queues at immigration, although they would need to pass though security regardless and if eligible for immigration e-gates it is often faster to go landside than through flight connections.
  15. jmh59
    jmh59 Member
    26
    7 May 2018
    Our local hospital maternity wing is a case in point. Newborns are carried through a haze of smoke usually generated by people attached to multiple drips on coat stands... but one has to remember it is your right to smoke and surely hospitals should make proper provision for people.
    As to flight comfort, having just traveled to Hong Kong on a half-empty plane I have to say that having a row of three seats entirely to myself was comfortable... but I think my leg length is just right so I can easily fit plane seats legroom-wise. Mind you I've never been on the cheapo carriers so I dunno.
  16. ashkeba
    ashkeba Member
    165
    13 May 2019
    The current provision is not proper, is it? There's no right to hurt newborns as they leave. If someone stood by the door slapping babies' faces as they left, they'd be carted off in short order!
    While those of us who are tall and beautiful find most planes horribly confining and even some exit row seats have legroom that makes most Mark 3 MU "airline" seating seem generous.
    Give me trains any time! If only international tickets weren't so dam fiddly.
  17. AM9
    AM9 Established Member
    6,456
    13 May 2014
    St Albans
    That's interesting, I will be travelling on a 787 to/from Calgary soon. Normal mif-flight air pressure is 7-8000ft, how much better is it on 787s?
  18. FQTV
    FQTV Member
    500
    27 Apr 2012
    A number of airlines, including no-frills carriers, have reasonably straightforward systems to allow you to book a ‘comfort seat’ - ie an unoccupied seat next to yours, or one between two of you if travelling as a couple.
    The seat has its own boarding pass, and is ‘onloaded’ at the gate so that it can’t be subsequently reallocated.
    The seat has its own naming protocol, which varies by airline. Jet2.com uses ‘MR EXTRASEAT [ASSOCIATED SURNAME]’, for example. On easyJet, it’s ‘MR SEAT CELLO’ as it’s the same system for large musical instruments.
    If fares are very low, buying an extra seat can actually be cheaper than buying an exit seat or seats, albeit meaning that the additional space is lateral rather than fore/aft, and you may not automatically get associated amenities such as priority boarding.
    The booking instructions are usually in the FAQ section of the airlines’ websites.
  19. EssexGonzo
    EssexGonzo Member
    401
    9 May 2012
    As someone who's 6'3" and wide (but not what you'd call a chubster), most affordable air travel is not comfortable. My days of an employer flying me business class are behind me.
    Ironically, in UK/Europe, nowadays I find Easyjet more comfortable than most BA flights. I suspect that BA have begun to tighten up their cabins and, of course, still have reclinable seats. It makes life so much easier when the option of dislocating my knee has been removed.
    But it's not just the plane - I loathe airports with a vengeance. The modern airport experience is rubbish and if I can drive or use the train, I will do so.
  20. Bletchleyite
    38,042
    6000ft, from a bit of Googling. It does appear to make a difference, as does the higher humidity. Love the big windows and the LCD "window shades" too.
  21. whhistle
    whhistle Established Member
    2,353
    30 Dec 2010
    Is it a right to be able to smoke?
    If so, surely I should be provided with free tools to do so?
    Is air travel comfortable?
    Now I think about it, not really.
    I don't travel by air often so still get a bit of a buzz when I do. But it's tiring. The seats are fairly padded but not very comfortable for long distances.
  22. edwin_m
    edwin_m Veteran Member
    14,766
    Air travel always involves the experience of airport security and queueing or simply hanging around in airports for long periods, which isn't particularly comfortable. It often also entails sleep disruption due to early starts or late evening arrivals, even if there isn't enough time difference to cause jet lag.
  23. theshillito
    theshillito Member
    272
    29 Jan 2014
    Crewe
    I'd consider air travel fairly comfortable. I've never flown Ryan or Easy though, so perhaps my thoughts on that would change if I did. Flying in a 787 with ANA between Dusseldorf and Tokyo (Narita) is lovely though (and the seats have seemingly got more legroom in my most recent trip compared to a few years ago). Eurowings between Manchester and Dusseldorf, along with Norwegian between Manchester and Stockholm also seem fine. Certainly not had an experience that I'd describe as "uncomfortable".
  24. Running Pete
    Running Pete Member
    9
    9 May 2019
    I find it mainly acceptable, it's the airports that mar the experience for me.
  25. AM9
    6,456
    13 May 2014
    St Albans
    In recent years, airports either have the feel of bus stations, e.g. almost all of those in the USA, or like the most intrusive areas of shopping malls, (painted women trying to spray the latest novel fragrance over everybody, passengers desperate to buy alcohol as if they are going to celebrate Christmas during their June Florida break, and bored kids of all ages).
    The latest irritation is the shops that you are forced to traipse through after clearing customs.
    How are the LCD blinds, do they impair pictures taken through the larger windows (when they are set to minimum obscuration of course!)?
  26. paddington
    paddington Member
    664
    19 Feb 2013
    The same is true for trains though. The reasons for early starts / late returns are that people want to maximise their destination time while reducing hotel nights needed, or because those flights are cheaper. But early morning and late night trains are more likely to have cheaper Advance / Sparpreis etc. tickets available too.
    Another thing about smoking - I spent most of March in the German/Germanic-speaking countries and every station platform was full of smokers, it was very hard to find a spot to stand where you couldn't smell it, and they never stopped! At least you don't get that in airports, and UK train stations are better though there are lots of vapers.
    Maybe a smoker can explain, but there seems to be something about trains that makes smokers so impatient for their next puff that they need to have the cigarettes in their mouth one station in advance and lighter in hand as the train slows to a halt, so they can light up the moment their mouth passes the door. And had a number of rude ones chuck their fag onto the platform just as the doors close then blow smoke right into other people's faces on the train.
    I find airports pleasant to wait in because I almost always have lounge access from airline status, even though I don't fly that much (compared to some), I just choose which tickets I buy so they earn me benefits quickly and cheaply. If UK trains had comparable "frequent basher" schemes they should be giving me free meals at every station with the amount of trains I take....
    As for queues, I avoid airports at peak school holiday times. IMO trying to board an XC train at New St during daytime is orders of magnitude worse than any of my experiences at airports.
  27. OneOffDave
    OneOffDave Member
    320
    2 Apr 2015
    Like most things it's a trade off. The 9 hours i spent on a plane yesterday was much more comfortable than the alternative transport methods would have been
  28. fowler9
    fowler9 Established Member
    8,075
    29 Oct 2013
    I've done several 12 hour plus flights in economy. They were all for leisure so that probably helped with me enjoying them. I normally don't mind flying at all including the airport experience. I can imagine in many cases of you have to do it for work it must be torture.
    Bad flights, actually the last one I took from Katowice to Liverpool. We spent the night before sleeping in the airport so I was tired, the Wizzair A320 was an older one, it was incredibly hot and very uncomfortable. Split to Manchester in September 2017 wasn't great either. Airport was massively overcrowded, plane was delayed and very hot. That one was Easyjet. Not their fault with the delay or the airport.
  29. class387
    class387 Established Member
    1,334
    9 Oct 2015
    No long haul economy flight is comfortable, though some are better (A350 or A380) or worse (787, 10 abreast 777).
  30. edwin_m
    14,766
    Trains are generally more frequent so there may be an option of a more convenient time. It may even be possible to get an off-peak train the evening before and a hotel for less than the price of a peak ticket in the morning. On most air routes there are a handful of flights per day, at times that suit the airline!
    Did you use a Split ticket?
  31. fowler9
    8,075
    29 Oct 2013
    Ha ha. Indeed I did. Was a great trip apart from Split airport.
Share This Page
