Doncaster avoiding line
Discussion in 'Allocations, Diagrams & Timetables' started by Scott M, 10 Jun 2019.
  1. Scott M
    Scott M Member
    276
    14 Aug 2014
    Out of curiosity is this line ever used, and if so what type of traffic uses it - freight only?
    Additionally is there any way of tracking whether a train uses lines like this on realtimetrains? So far the only way I have found would be to click on every train that goes through Hexthorpe junction, and see which ones also go through Bentley junction without passing through Doncaster - but this is somewhat tedious.
    Rail Forums
  3. Bertie the bus
    Bertie the bus Established Member
    1,310
    15 Aug 2014
    There are three Doncaster avoiding lines. Which are you referring to?
  4. Scott M
    Scott M Member
    276
    14 Aug 2014
  5. Darandio
    Darandio Established Member
    7,334
    24 Feb 2007
  6. STANDISH
    STANDISH Member
    213
    10 Jun 2013
    Can be done by excursions or rail tours which avoid the station
  7. rick pike
    rick pike Member
    48
    6 Jan 2013
    Grimsby
    Off the top of my head there's the already mentioned Scunthorpe to Eastleigh rails and steal trains between Masborough and Hull or Goole
  8. DarloRich
    DarloRich Veteran Member
    22,347
    Work - Fenny Stratford(MK) Home - Darlington
  9. dk1
    dk1 Established Member
    7,311
    2 Oct 2009
    East Anglia
    Indeed. The only reason I paid £70 for a railtour a few years ago was for this one section of required track.
  10. anthony kelly
    anthony kelly Member
    9
    19 Dec 2018
    DERBY
    This line is freight only but has been used in br days for weekend diverted traffic
  11. _toommm_
    _toommm_ Established Member
    2,568
    8 Jul 2017
    Glossop
    Any service that goes direct from Conisbrough to Kirk Sandall i.e. not going through Doncaster, uses this line.
  12. Scott M
    Scott M Member
    276
    14 Aug 2014
    Thank you for the replies all. :) Figured it would likely be freight and ECS only, hadn’t considered charters though.
  13. at60
    at60 Member
    71
    13 Nov 2012
    I live about a mile from this line, & though I haven’t checked RTT recently, there used to be around an average of 7 or 8 freights daily.
    I also, like you, found the best way to search was by searching Hexthorpe jcn, then checking back or forward from there to work out the route. I personally have never seen a passenger service on the avoiding line, despite working in the area & also cycling alongside it regularly.
Share This Page
