I rode out to Dane Road last week, and the ride in both directions (including the fast bit over the Mersey) was pretty good compared to my previous experiences.
NR can’t even be bothered to fix the points on the heavy rail side after Navigation Road crossing which is why all of the trains have to go onto the wrong track on departure from Altrincham towards Stockport. That been like that for more than a year.
When services to Ashton first opened in 2013, the trams went to Bury. It wasn't made clear then that this was not going to be permanent, just as it wasn't made clear that the trams which currently run to Etihad Campus would ever run there in service - they used to run empty stock from Piccadilly and they were sent there simply because of a lack of capacity in the turnback. The passenger service from Altrincham to Etihad Campus did not run for very long before being stopped while St Peters Square was rebuilt either. These sort of changes are quite common. This change marks the first time in almost about 8 years when the service pattern could be considered to have 'settled down', there has been a constant state of flux somewhere or other since MediaCity opened (remember, the service from MediaCity was initially only to go to Cornbrook).
There is an oppourtunity to change the service again in future, and there is the Trafford Centre service to overlay on the current pattern. However I would say it would be good if we could keep the pattern the same for a couple of years at least, and gather some data about who actually travels where and when as far as the cross-Manchester journeys are concerned.
You could also make the point that these timetable changes finally realise the full benefits of building phase 3 which began right back in 2009, as they would never have been to this extent without 2CC. Crucially it means that those who travel from Northern Moor and other stops on the Airport line will at long last have direct trams to St Peters Square and Exchange Square, right in the city centre.
Is it not to Crumpsall to where the new Trafford Centre tram service, when operational, will be terminated?
Correct. The point was that the routes post-recast (including Trafford Centre-Crumpsall) don't have to be set in stone forever.
The service pattern could be Altrincham-Crumpsall, or Ashton-Crumpsall with Trafford Centre running to another terminus.Can you think of another reason as to why the proposed upgrading of Crumpsall should then go ahead?
I notice on the map that the Oldham branch service currently has one route terminating at Shaw/Cromptom and one going all the way to Rochdale. The TfGM website says that all services operate every 12 Min, therefore a 6 Min service via Oldham to Mc’r and East Didsbury. The new map shows this as a single line from Rochdale to East Didsbury; will all Trams now go to Rochdale or is it just to simplify the map?
I thought as much; after all I don’t think I’ve ever seen other Metros have a separate line for “shorts.” Presumably the statement that all services run every 12 Min during daytime hours will be withdrawn.I believe the lengthy single line section between Rochdale Railway Station and Newbold precludes that — it's almost certainly just a map simplification.
Previous posts suggests the Shaw & Crompton short workings have been consolidated with the Rochdales into a single line on the map, so it is every 6min in the centre.Looking at the new map, I see only one service running through the Second City Crossing; East Didsbury to Rochdale. That doesn't appear to be a stunning return on investment to me.....
Metrobus?Don't forget 1CC serves Shudehill bus station that has a very wide range of bus service routes and Metrobus,
Metrobus?
What on earth is that Paul?
Sam
Metrobus?
Sam
Oh dear, I meant Megabus..
Too much time spent on "The Transport Game UK" on the Quizzes and Games forum. Metrobus covers South London, Surrey, Kent and Sussex. After some changes over the years, whilst the name Metrobus is still kept, the company services are now run by both Go-Ahead group and by Brighton & Hove.
Looking at the new map, I believe that Market Street should really be featured as an interchange blob, not the basic 'stop' it is currently indicated as.
But, back on topic, I also note that the TfGM website now displays this banner:
The reason that Airport teams are going 1CC is because at the moment the only services which run between St. Peter’s Square and Market Street/Shudehill are the Altrincham-Bury services which run every 12 minutes 07:00-20:00 Monday to Saturday with no Sunday service.Does surprise me that Airport trams are to be routed via 1CC - I'd half assumed it'd be via 2CC.
Would presume that means the eventual Crumpsall-Trafford Centre will be via 2CC - Mosley Street capacity will be maxed out already with 25tph (10 Alty, 10 Salford Quays, 5 Airport)
St. Peter’s Square to Victoria via 2CC already has a 6 minute service frequency.
I think that Trafford Centre - Crumpsall is going 2CC which would give 3 vehicles per 12 minutes.
