I like the door controls on the M5000 trams in Manchester and suggest that a lot of suburban rail stock could copy them.
You can push the open button at any time. It then flashes, and that door opens when released. Obviously, if you push it after the door is released, it opens immediately.
It means I can put down luggage, push the button and then pick it up again and have it in hand when the door opens so I don't block the doors picking stuff up after pushing the button.
It's a very good feature, shared by various Continental trams (the door button often also requests a stop) but no others in Britain as far as I know. But it does create a hazard. If the driver (or, on a train, the guard) opens the doors on the wrong side then no accident normally results unless a passenger also presses the "door open" button. However with this feature the door will open if someone has pressed the button previously.
A similar situation in respect of someone leaning on the door is probably why door controls on more recent trains don't operate if someone is holding the button down as they are released, but older trains do.
