Double deck trains - again ...
Backroom_boy
28 Dec 2019
I could see doubledecker trains on the Eurostar services. Isn't it already cleared gauging wise for the route?
stuu
2 Sep 2011
Yes, HS1 is designed to the same standards as the French LGV network, so not a problem
Bristol
The issue for Eurostar running double deck trains would be meeting the evacuation requirements in the tunnel. It's certainly not insurmountable, but it is another barrier to clear.
AM9
13 May 2014
St Albans
Is that really true? I am sure there must be routes that are not accessible to 26m long IET stock due to platform curvature clearances.
I believe that the clearance for the 26m long class 8xx stock is the same as for MK111 23m stock. This is achieved by insetting the bogie centres to:
maintain a similar inswing at the centre of the cars. the additional outthrow at the ends is reduced by the cars having a tapered profile​
the overall width of the cars is slightly reduced​
By these means, the routes permitted for the class 8xx stock is very similar that for the MK111 profile.
Haywain
3 Feb 2013
That's not the same as what was suggested, which was that new stock must be able to access 101% of the network.
Because all stock, irresp' of propulsion, must be capable of being hauled on 101% of UK's infrastructure inc' non-electrified track with its neat fitting arch bridges & tunnels.
Technologist
29 May 2018
I think you've missed my point. I'm asking why BEMUs need to completely rethink acceleration rates when existing trains already achieve extremely good performance that results in competitive journeys. See reports abound of 80Xs running into problems overspeeding because the acceleration is massively more than legacy stock. Why do we need to completely redraw the curves when we could simply design BEMUs to achieve the 80x or 700 power outputs?
I'm a big advocate of BEMUs being a fundamental part of the long-term railway low-carbon solution. I'm not advocating against BEMUs at all.
Industries die when they decide that something is good enough and when backwards compatibility stops new products operating to their full potential. The performance of a class 800 might be acceptable when compared to an older train, however if it's compared to a self driving car or an eVTOL much less so.
If all trains can accelerate very rapidly stopping trains cease to be obstructions and thus we can run far more lines like metros vastly improving user experience. Not running mixed traffic also means that line speeds can be increased and rapid acceleration means that you can hit those line speeds.
stuu
2 Sep 2011
They really don't. Acceleration isn't that big a deal on trains which run medium to long distances, it doesn't save that much time. 1.3 m/s2 (constant) gets you to 125mph about 1.5 minutes quicker than accelerating at half that rate, which is about what 800s manage on electric power. Even XC journeys only stop every 20 minutes so you might save 3 minutes an hour. Game changing
Technologist
29 May 2018
You're missing my point, the rapid acceleration can be applied to every train on the line so that your stopping service accelerates viciously to the line speed (which is then worth investing in raising as more trains can hit it). Combine with designing these trains for tube/commuter dwell times and there isn't a need for express trains as the end to end journey time for a stopping train is at least as good as where the express trains were. Stopping all trains at all stations then means that you can run far more trains.
Now combine with changing planning laws so you can build densely around any station not in an SSI and you have the potential to gives large amounts of the UK a London style commuter rail service that allows long distance walk up and go services. The economic growth related to doing this would be massive, the industry should have this level of ambition.
For full pendry my modelled train was based on class 800s swapping all the diesels and fuel for LFP battery packs, this could conservatively achieve about 3.6 times the power output of a class 801. Obviously you could add more batteries and you could treat them harsher, I designed for a 5C discharge rate, you could go to 10C no problem.
So a class 800 accelerates at 0.7m/s/s until it hits ~57kph, then it tails off, the BEMU goes at 1.3m/s/s until it hits ~112kph. From that point on the BEMU accelerates 3 times faster.
Trainbike46
18 Sep 2021
belfast
While I absolutely see the benefits of faster acceleration, and 1.3 m/s is absolutely realistic on the mainline railway network, because some trains already do it, I wonder what any of this has to do with the, for the UK terrible idea of double-deck trains?
Back to acceleration, the UK FLIRTs have these acceleration speeds provided by Stadler, though I have no clue how these develop through the curve:
On AC power:
  • 755/3: 1.3 m/s2 (4.3 ft/s2)
  • 755/4: 1.1 m/s2 (3.6 ft/s2)
  • 745: 0.9 m/s2 (3.0 ft/s2)
  • 756: 1.1 m/s2 (3.6 ft/s2)
On diesel power:
  • 755/3: 0.7 m/s2 (2.3 ft/s2)
  • 755/4: 0.9 m/s2 (3.0 ft/s2)
  • 231: 0.9 m/s2 (3.0 ft/s2)
You spend the three minutes an hour adding extra stops.
In such an environment you can make stopping trains with minimal journey time disadvantages versus express trains. You can then achieve major "effective" journey time improvements by replacing a mixed stopping/semi fast/fast timetable with a uniform timetablne, putting functional frequencies through the roof.
But I agree this is peripheral to the double deck train argument - but does demonstrate the sort of high capability railway that is buildable with current technology.
Increasing loading gauges will make high capability trains easier to build, although I'd rather focus on extra width if we can get it.
MarkyT
20 May 2012
Torbay
On AC power:
On diesel power:
Another modern Stadler train, Merseyrail's cl.777, is far more powerful than the cl.50x units they replace. Car weight is also reduced significantly with the articulated bogie configuration.
Unit Class
No. of Cars
Total Power (kw)
Total Weight (t)
kw/car
~t/car
kw/t
507/508​
3​
656​
105.00​
218.67​
35.00​
6.25​
777​
4​
2100​
99.00​
525.00​
24.75​
21.21​
Somewhat associated with this is a question, double decker trains will likely lead to a larger loading gauge with the attendant major structural modifications.
A larger loading gauge would allow trains to load more people into the same length, but in some constrained areas such modifications would force a reduction in the number of tracks.
If we could have trains the size of Superliners or E4 series shinkansen vehicles, would a reduction in tracks be tolerable, especially given the performance that modern multiple units are capable of?
Height is the main constraint. Wider wouldn't be hard by, as you say, removing tracks on 4-track sections. But RIC stock isn't that much wider than UK profile anyway (albeit with the platform protrusion issue) but it is much higher. UK loading gauge is lower than a double decker bus.
Wider is very hard because of platforms and other lineside structures.
It's much easier than higher if you're willing to lose tracks. It would require platform rebuilding, but this is a lot cheaper than replacing every single OHLE support and bridge/tunnel.
The fundamental issue is that UK loading gauge is too low. If it was two feet higher you'd be able to do something, albeit probably only 2+1 seated downstairs (full width upstairs though - it'd be shaped a bit like the Dutch DD-IRM units with a bulge above platform level). But as it is you don't have the height for two full decks.
Well reduction in number of tracks also aids height in some cases, for example all our arched bridges.
If you have a four track railway with two two-track arch bridge spans, going to four tracks would allow the track to move into the centre of the arch, which will get you a non-negligible amount of height as well as width.
SImilar idea in existing twin track tunnel bores.
Trainbike46
18 Sep 2021
belfast
changing the loading gauge in such a significant way, whether for widening or for heightening, would be really expensive, involve very disruptive infrastructure works, and, as far as I can tell, simply would not be worth it.
Best to just accept that double-deck trains won't happen outside HS1 and maybe HS2, and instead increase frequencies or extend train length.
Mikey C
11 Feb 2013
Also, could STP's passenger lounges cope with even more people on a single service?
MarkyT
20 May 2012
Torbay
This technique gained space in tunnels of the Tonbridge - Hastings line to overcome especially narrow historic loading gauge due to original substandard construction requiring an extra lining. They only singled the higher speed tunnels though. Either side of Tunbridge Wells, they kept double track with a low speed restriction applied and concrete slab instead of ballast and sleepers was used in tunnels to limit the dynamic envelope (mainly how much cars can swing side to side in motion) and reduce the risk of any track movement.
What happens when we hit the limits of frequency (set by timetable limitations and physical infrastructure) and train length (set by the same infrastructure).
Trying to boost train lengths on many routes today is going to be just as disruptive as a total reconstruction to a new loading gauge.
You meant to write going to two tracks presumably? Academic though, because I just don’t see anyone seriously proposing converting any of the existing four track railway sections to two track.
Trainbike46
18 Sep 2021
belfast
The few lines where this is likely to occur can be resolved by building new lines, for example HS2, built to a larger loading gauge from the start. The amount of work needed to increase the loading gauge is effectively a complete rebuilt anyway, and if you're doing things like turning 4-track railways into 2-track railways you are then decreasing capacity again.
Another option is what is discussed upthread: increase acceleration, use the time gained to add extra stops (for the faster services), or to reduce the average speed differential between services (by increasing the average speed of slower services), decreasing effective journey time, and increasing capacity for more trains using the lower speed differential between services.
However, on many lines extending train lengths or frequencies is still possible, especially if HS2 gets built to at least Crewe (and ideally beyond there)
Bristol
I'm struggling to think of anywhere that would justify rebuilding for double-decker trains yet have sufficient capacity to remove tracks. There are isolated locations where tracks have already been reused and the spare trackbed could be reused, but I don't think any of them would extend as far as necessary to provide double-deck clearances throughout.
The other big issue, as mentioned, is with platforms. In particular, platforms built to the minimum width for UK profile would need to have an equivalent space moved backwards (or derogation from the standards approved) to allow the requisite width shaved off the rail side of the platform edge. This is going to be a huge problem at most major stations, if not all and plenty of smaller stations besides. UIC gauge isn't massively wider, but if it's foul, it's foul.
It's kind of moot really because without an extra two feet or so of height it's simply not feasible. The height above railhead of UK loading gauge is less than that of a double decker bus. The 4DD gets quoted, but really that was a one-and-a-half-decker.
Were it not for the height thing, you could do 2+1 lower deck (or commuter width 2+2) and proper 2+2 upstairs.
Sorcerer
20 May 2022
Double-deck trains are heavier than single-deck trains and will require more power to accelerate and decelerate, and cause of the extra weight it will add to the extra track wear even if the traction motors can be made powerful enough to match the acceleration of single-deck trains. They also require longer passenger dwell times which will eventually lead to less line capacity, and all for about 1.5x extra passenger compacity for individual trains at best.
But in the UK this would be optimistic since you'd end up reducing capacity by having to move undercarriage equipment around to accommodate a lower floor, and cause of the more restrictive loading gauge you'd also end up with 2+1 seating on the top deck (like on the conceptual AeroLiner 300). Aesthetically the train looks nice, but it also looks really cramped, and passengers most certainly don't want to be crammed in like a tin of sardines.
Upstairs you'd fit in 2+2. The narrow part of the UK loading gauge is below platform level where it'd have to be 2+1. But the problem is height.
Oops, yes sorry.
Bristol
BR W6 is 3.965m above rail level, UIC GA/GB/GB+ is 4.320m above Rail level. It's not impossible that with a very low floor and accepting low-ish ceiling heights of 2m-1.8m you could fit 2 full decks in the UK. It wouldn't be worth it at all but that's a different kettle of fish.
If in the 50s BR had started a policy that all new bridges were build to 4.5m clearance, oh what a different world we might yet have lived in...
main-qimg-7b72ecbe1b96a6ada5b74df337bd434f
To give an idea of just how cramped this would be, an Alexander Dennis Enviro400 double decker bus is 4.2 to 4.3m high depending on the height specified. And upstairs is pretty cramped on those already without having to lose an additional 30cm or so between the two decks.
It's just not feasible.
