Jozhua
- Joined
- 6 Jan 2019
- Messages
- 1,856
You're basically describing the Bombardier Omneo product currently being introduced by SNCF and the French regions for TER services (and eventually for Intercités and some Paris Suburban routes.)
Link is to the Bombardier Omneo Wikipedia page in English.
TER = Transport Express Régional - Regional Express Transport
As it appears, yes! In fact the design looks much better than my quick scrawls, having shorter single level carriages to allow for even more two floor space and shared bogies, which further reduces space and increases safety.
The design is still quite a bit out of UK loading gauges from what I can tell, although it looks like it has been designed to maximise the french loading gauge as it advertises itself as wider than the average french double-decker train.
Anyway, so I did a bit of poking around to see if I could compare the specifications of this train to the loading gauges of the UK. Although for the most part it seems quite restrictive, there are different classifications, with different areas of the network having larger gauges. These are all classified as "WX" something, with W6 being the most common, but a suprising amount of the network conforming to the W10 standard:
https://cdn.networkrail.co.uk/wp-co...nced-W10-loading-gauge-map-of-the-network.pdf
Still the W10 standard allows trains to be 2.9 meters high and 2.5 meters wide, which is still short of what most bi-level trains around the world conform to. Even on Japan's narrow gauge rail network, their trains are still able to be both wider (4.1 meters high and 3 meters wide) and taller than ours, even though they are limited to 75mph.
Even the most liberal UK standard, W12, is still just 2.9 meters high and 2.6 meters wide.
Unfortunately, our network still falls a meter short on height and half a meter short on width, so we really are significantly limited, unless some breakthrough space saving designs can be created. Obviously as well, the loading gauge is likely not a strict square and the shape of the gauge could allow for some deviations here and there, although I couldn't find any particular diagrams. Maybe some newly re-worked routes may be suitable as well as the newer HS1 and Crossrail networks.
