Dream train design!
Drsatan
24 Aug 2009
Land of the Sprinters
For me, it would be an SBB IC2000 set, but with IC70 seats and hauled by a class 90. However, since the likelihood of a double deck train running in the UK is very small, I would be happy with an AC-powered version of the 442, but lengthened to 10 cars and fitted with streamlined cabs similar to DB's cab cars. Such a train would have a restaurant and bar car, and have interiors in first and standard similar to those found on DB's ICE3 EMUs.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
The Heathrow Express 332 interior in standard class would have to become a feature of the 170s surely; it looks perfect!;)
http://www.railforums.co.uk/showthread.php?p=1126727
Strangely, that unit reminds me of a cross between a 442, Juniper, and a terry's chocolate orange!
Does make you wonder though, if something similar could have been incorporated into the 378s, although of course it would probably come up against some law / restriction etc, amd when do 378s ever work in pairs?
asylumxl
12 Feb 2009
Hiding in your shadow
Theres are rules on miimum sighting from trains with and without gangways. I imagine that such a system would probably reduce field of view further and not be doable.
MCR247
7 Nov 2008
It was do-able in theory with 458s - why couldn't an upgraded version work?
150001
24 Jul 2011
If there was no front gangway, the forward visibility would be much better. There'd be less drag too with the big chunky door sticking out. The 378s would still have the same view out the front from the driving ends; all the gangway is stored compactly (on the Class 259) behind the front end door.
Bevan Price
22 Apr 2010
Bulleid SO coach, body strengthened to meet modern collision regulations. No air con, local passenger-operable controls of under-seat e.t.h., sliding windows that can be opened by passengers. Spacious comfortable seating.
(A Merchant Navy at the front would be an added advantage, but failing that, a class 92/1, designed for operation at 125 mph and fitted with e.t.h. )
bronzeonion
1 Apr 2009
West London
The cab is located above the gangway on the E259 series, there is a route from the saloon to the gangway connection which avoids the small staircase to the cab area, like how to get from a Voyager saloon to the exit doors, you have to avoid the oversized toilet area!
