Deafdoggie
- Joined
- 29 Sep 2016
- Messages
- 3,079
Crewe also sign to Walsall.
I believe LNWR have plans for Manchester Airport? And will the May timetable change mean Crewe Crew do go via Birmingham to MKC?
Hello Guys im new here is anyone who wants to give a bit advice how can I apply for a train driver position here thx a lot
Thanks - yeah I need to do a complete overhaul of the Thameslink section.Horsham, Orpington, Gillingham, Cricklewood, St Albans and Luton have been active TL depots since May.
Cheers for all the updates - all edited inPeterborough is a mixed TL/GN depot now
Pedantry edit suggestion - Gloucester actually has TMs and Conductors, albeit all in one link. They are (currently) a separate grade
The Gloucester guard scenario makes my brain hurtPedantry edit suggestion - Gloucester actually has TMs and Conductors, albeit all in one link. They are (currently) a separate grade
It's easy for us, they're all one depot and we use as required. Just have to remember the actual TMs get first shout for the HSS jobsThe Gloucester guard scenario makes my brain hurt
PAD-Malvern via GCR, Pad-BTM via box, Pad-Cdf. Swindon-Gcr, Btm-Severn Beach, Taunton and Westbury. Westbury-Swindon via Melksham.
150, 153, 158/9, 165/6 IET and HST
Conductors don't sign HSTs (but do IETs) and some are starting to learn Paddington
Edited in, thanksSwindon needs adding as a driver depot for GWR as of tomorrow (27th)
EDIT: also Heathrow Express should probably be removed entirely - they're now effectively under GWR Paddington, although HEX drivers are strictly speaking a separate grade at present.
Probably easier put as Pad (LTV) Pad (HEX)Swindon needs adding as a driver depot for GWR as of tomorrow (27th)
You can easily apply when vacancies appear.Hello Guys im new here is anyone who wants to give a bit advice how can I apply for a train driver position here thx a lot
Edited in, thanksAbbey Wood now operational for Crossrail.
Is abbey wood now a depot for cross rail?
Ah, could have sworn I put those in! Edited in, thanksFor ScotRail, both Corkerhill and Shields depots are driver depots also. Other than that the lists are perfect.
