A pound for every time an S.W.T. Guard comes through doing tickets on a suburban train won't leave me out of pocket much.
It's highly unlikely you would ever see a SWT guard sell tickets on suburban services as they are mainly non commercial turns. You'll see them every now and again but not on a regular basis.
Someone in an earlier post asked about D.O.O. on S.W.T. suburbans. Well, the equipment was installed, the trains were equipped then Bonehead Bob stepped in, frightened everyone and the then weak management backed down and even - under union pressure - agreed to remove the station equipment. D.O.O. will come in on S.W.T. one day, there is absolutely no requirement for a Guard to be sitting in the middle cab of an eight car E.M.U. telling people that, "I'm in the centre of this train if you need me" on lines that are T.C.B. signalled with G.S.M. radios. That person's job is to be swanning up and down the train being a visible presence.
Actually Bob had very little to do with the current working arrangements, BR tried to implement DOO in the 1980s but failed to do so successfully. Souter is no coward and if he really was prepared to make the grade redundant he would have done a long time ago.
If you feel so aggrieved that the guard dared not to patrol your train then report it (and quite rightly so) we are meant to be out there providing a presence and reassuring passengers. One would like to think with the reductions in platform and ticket office staff you lot would want to keep the guards on the trains for general inquiries and information.
While GSM-R may make emergency protection redundant its still good practice to have a competent personal onboard as well as the driver. An on board manager or ticket examiner who doesn't have a clue about track safety, train evacuation proceedures, conversing with a signaller/ECO or securing the train in the event of a division or even worse a drivers death, quite frankly is not.
Most of SWT's suburban or outer suburban services are eight to twelve coaches long, and you in excess of nearly a thousand people when the trains are full and standing. Are you telling me a driver is more than adequate to evacuate the train in an emergency? Personally speaking I don't think a driver and a guard is enough and once passengers start pulling the egress it's like hearding cats.
What may work with a three coach train in Strathclyde, may not work with a 12 coach train in and out of Waterloo. Now if one were hell bent on implementing DOO it may not be as simple as you may think. SWT's 455s have not long had a major refurbishment and they modified the coaches so the guard can perform a full door release from any coach in the train. To go DOO on them would require more work on them as the driver would have to get out of his seat and go into the vestibule behind the cab to release the doors. 458's as far as I can tell the driver would also need to get out of his chair depending on what side the platform is.
450/444s may also pose an issue, I had read that the reason 360s have no gangways is because the HSE were not happy with the visibility afforded to the drivers on the 350/450/444 units for DOO operation and since the 360s were designed to be DOO from the outset Siemens changed the cab design, if this is true SWT's Desiros may require significant work on them to get approval for DOO. Could someone whos is a little bit more clued up on Desiros shed any light on this?
Bottom line is though chaps, getting rid of guards will not make your tickets any cheaper and you've just gotten shot of an extra person who may well make a difference in the unlikely event of an emergency.
