This incident is actually used in training and safety updates. I did mine about 6 months ago.
Communication and more importantly correct communication is what it is all about.
So we all learn a little bit after evry incident. I found this report to be very interesting and more or less acurate to the film they showed us.
Yes a complete cock up in communication from start to finish. It's not the easiest bit of railway to report problems, it's a long section of automatic 3 aspect signals through rural countryside. The chocolate poodle bridge, named after a local pub, is one of the nearby landmarks, where the train stopped.
Nevertheless, it raises some interesting points. The driver should have contacted the signaller by the quickest means possible to get full protection (Rule book section M) He didn't even pick up the phone 200 yards away, on an automatic signal. He used his mobile, didn't have the right number, and when he got through to Westbury instead of TVSC didn't state it was an emergency call.
A guard was provided on this train, yet the exact whereabouts of the track wasn't known for 30 minutes - aside it was in a mile long signal section.
Let's say DOO was in operation - incidentally DOO operates just east of that point on 165/6 trains. The driver would have called on a cab secure radio through to the controlling box, probably using a emergency call, so minutes saved there, and the correct signal number would have been displayed - more minutes there. An emergency broadcast could have been made, to all trains in the area. Much of this applies to GSM-R which is being fitted nationwide.
If the driver had been injured or killed, there is nothing to prevent a conductor making a similar emergency call. Beyond that there's nothing to stop TOC's fitting all trains with GPS for pin-point accuracy. I think Northern rail did it on the Whitby branch.
While the train manger did put down a track circuiting clip, this would be no more effective than using GSM-R using an emergency broadcast.
In this case, the train crew took 26 minutes to make contact with the TVSC simply because it was worked the old fashioned way with Guards, SPTs (not always conveniently placed) etc.
So I'm not sure what the argument is? Surely modern radios, GPS, is the way to go?
