DRS liveried 68s in service with Chiltern
Harbornite
7 May 2016
I'm aware that DRS liveried 68008 and 68009 take turns to work chiltern mainline trains, alongside their chiltern liveried counterparts nos. 68010-015.
Can anyone confirm if 68008 will still be on chiltern as of tomorrow because they switch between 68008 and 009 every so often. However, I don't know how often they swap them.
Once again, thanks in advance.
3 Mar 2006
GEML/WCML/SR
68008 & 009 are both in the Chiltern pool and used in common with the silver ones. 008 is out today, 009 is off patch on exam.
Harbornite
7 May 2016
Thanks for that, so this means I have a chance go copping 008 tomorrow on Chiltern.
Peter Mugridge
8 Apr 2010
Epsom
Assuming they haven't swapped it between rakes since Saturday it'll be attached to 12605/12625/12616/12614/12607/10271/82304 - that might make it easier to locate as I gather the carriages show up on more systems than the locos themselves do.
Harbornite
7 May 2016
Thanks. I'm not really familiar with chiltern mark 3 numbers but I assume that is not the banbury set?
Peter Mugridge
8 Apr 2010
Epsom
If it's out and at a time / direction you can get it from, of course. Then again, if you can be in the Birmingham area all day ( which your location suggests is highly likely! :) ) they all serve Solihull and Moor Street don't they...?
Harbornite
7 May 2016
That's right, my initial plan was to see it at Tyseley but I've revised my schedule and I'm gonna head to Leamington instead.
168lover
2 Aug 2013
Chiltern Mailine Land
Apart from the Banbury set one which I think is 015 at the moment.
Peter Mugridge
8 Apr 2010
Epsom
5 daily diagrams including the Banbury set, 8 class 68s in the pool including the two spares, so "if it's out" most certainly applies...
Harbornite
7 May 2016
014 and 015 were in service on silver sets, I didn't see 008 at all because it went down very early in the morning.
D6975
26 Nov 2009
Bristol
If it went down early in the morning and didn't come back, then it was on turn #4.
If it sticks, it will be on turn #2 tomorrow
1Y12 OXP 0724 - MYB 0820 (2)
1R15 MYB 0841 - BMO 1044 (2)
1H33 BMO 1055 - MYB 1241 (2)
1R33 MYB 1310 - BMO 1459 (2)
1H62 BMO 1555 - MYB 1742 (2)
1K54 MYB 1815 - KID 2048 (2)
Harbornite
7 May 2016
Damnit, I will have to get it another time.
Finally copped it!
