DRS Stowmarket
The One
2 Apr 2010
Apart from the RHTT work what other work do this depot do during rest of the year.
Cheers
mwest123
15 Apr 2020
Colchester
Cheers
DRS Stowmarket generally do shunting, loco hauls to and from Crewe and York (and other major DRS engineering bases, often via Willesden) and engineering possessions in the GEML area, for example they did one at Great Bentley a few weeks ago with the famous Concrete Bob. Sorry you haven't got a reply, there are only a handful of drivers at Stowmarket depot. It is hours based so during the spring and summer you get basically the whole time off apart from a couple of moves to and from Crewe here and there, but in the autumn and winter you work flat out with RHTTs. Hope this helps. If you are applying, I would highly recommend it if you don't mind working flat out in the autumn and winter and love a good old 37!
The One
2 Apr 2010
Thank you for your reply how many week ends you get rostered i assume you must work to a roster eg 13 week roster
Cheers
mwest123
15 Apr 2020
Colchester
Cheers
I don't work for DRS so I wouldn't know that. Someone from another depot or DRS recruitment may be able to help as AFAIK there are a few vacancies up on the careers page for drivers, possibly with that information. Hope this helps :)
