Dyce rail station to Aberdeen Airport
AJG3
9 Jan 2015
Hi,
anyone know what's the best way to do this on a Sunday; I can't find a direct bus service....taxi, walk??
Thanks,
Andrew
Romilly
5 Nov 2013
Maybe travel to Aberdeen railway station and then get the 727 bus (every 20 minutes, journey time 25 minutes, on a Sunday).
Or about 2.5 miles walk from Dyce station to the terminal on roads skirting around the south side of the airport.
Otherwise, a taxi.
Volvodart
12 Jun 2010
You could get a First 17A from Dyce to Bucksburn Police Station and cross the road to get the 727. It is not far from Dyce Station to the Airport, so a taxi fare should not be too much though.
cf111
13 Nov 2012
I always go into Aberdeen and get the 727 from the bus station.
me123
9 Jul 2007
The bus service only runs on weekdays. So on Saturday and Sunday you cannot get to the airport's railway station unless you take a taxi (£9 when I did it - you can't help but feel cheated when you get out of the taxi and see the aircraft you stepped out of moments before :x ).
At the weekends, you are much better to get the 727 to Aberdeen City Centre and connect with rail services there. I'd only waste money on the taxi if I was going towards Inverness, where the low service frequency means that you may face a considerably longer journey if you don't. All in all, the 727 bus is by far the best way to get between Aberdeen and its airport - when I lived there, using the train never crossed my mind.
Yes, it is a disgrace. That's Aberdeen for you. Bear in mind that the 727 bus is actually relatively new - it launched in 2010, and before then you were stuck with either an infrequent train or a horrendously overpriced taxi.
