Easements Updated (30/7/12)
SS4
30 Jan 2011
New Easements list here. Updated on July 30th according to the file name but uploaded on 2nd August.
Still going through it but I notice easements 2, 3, 4, 6 and 7 have been pulled from the old version (does anyone know a better way to see what's changed than manual checking? - diff doesn't work on binary files like pdfs)
Oscar
Fares Advisor
11 Feb 2010
Switzerland
700285
Customers travelling from Shrewsbury to London Euston in possession of tickets routed "ATW and LM only" may not travel via Crewe. This easement applies in both directions.
Is this easement new?
SS4
30 Jan 2011
Yes, that's a new one.
edit: the new ones shouldn't be hard to find, I'll add them
edit2: OK, there are a fair few new ones (assuming they're simply appended to the end of the old list) so I shan't post them in full but the first new one is 700227
700227
Customers travelling from Colne, Nelson, Brierfield, Burnley Central, Burnley
Barracks, Rose Grove, Hapton and Huncoat to Horwich Parkway in
possession of tickets routed 'Any Permitted' may not travel via Preston. This
philjo
9 Jun 2009
This one seems to make the journey impossible !
700119
Customers travelling from Shelford via Royston, may not travel via Cambridge. This easement applies in both directions.
RJ
25 Jun 2005
Back office
Given that Shelford is a TOPS reporting point, I still suspect that this is intended to prevent more significant abuse of map WA. Of course, the only available ticket for that flow is routed via Cambridge!
34D
9 Feb 2011
Indeed. And I believe that when we previously debated which comes first out of a 'route x' or an easement, the answer was the most favourable to the passenger.
maniacmartin
Fares Advisor
15 May 2012
Croydon
I don't seem to be able to upload HTML files - so I've made a diff of the PDFs here
https://static.maniacmartin.com/temp/easements-diff.html
Some of the existing easements have had their wordings changed subtly - specifically "doubleback" now doesn't contain a space. Click the 'n' on the left to jump to the next thing that has been changed. Easements 2, 70 and 300444 appear to have been removed
I've just noticed that the "old" version I compared with must be newer than the old version SS4 used, given that 3,4,6,7 were already gone from my version (downloaded on 9th July 2012). If you want to send me your PDF I'll make a diff from it
Chapeltom
23 Feb 2010
Tainan, Taiwan.
Some of these are plain daft
Journeys from Stockport to Stalybridge may go via Manchester. Journeys via
Stockport and Stalybridge may go via Manchester. These easements apply in
both directions
If the easement didn't exist, the journey would be impossible 99.9% of the week.
All Line Rover
17 Feb 2011
700285
That's interesting. Easements can now apply to specific ticket types, can they?
(In any case, London Midland have a right cheek to introduce a negative easement after refusing a customer request to introduce fares between Shrewsbury and Crewe. :roll: If this is how they act with individual customers, imagine how much they must have complained to Virgin about the Railcard easement!)
SS4
30 Jan 2011
Definitely possible, I was using an outdated version. Don't worry about the diff but thanks for the offer :)
island
30 Dec 2010
both directions
A number of easements are in the nature of "hacks" implemented to force routeing and booking engines to behave as we expect them to.
barrykas
19 Sep 2006
700060 (Customers in possession of tickets routed LONDON may not travel via Ebbsfleet International) breaks fares from Chiltern's "Heartlands" area (essentially Denham to Haddenham and the branch to Aylesbury) to stations for which HS1 is perfectly legitimate, as they're routed via London, whereas other TOCs mostly use Any Permitted for such tickets.
island
30 Dec 2010
To be ultra-technical that easement is meaningless as there are no fares routed LONDON since last October, but that's probably not what they had in mind.
kieron
22 Mar 2012
Connah's Quay
I've had a look at these, and it seems like the TOCs have been fairly generous this month.
Easement 2 has been replaced with 700269, which appears just to replace "go" with "double back". Has this killed off the "any permitted" Lowestoft-Felixstowe tickets via Norwich and Ipswich, or have they just changed the number?
Easement 70 has been replaced with 700282, which restricts the valid start points at the Faygate end.
Easement 300444 has been replaced with 700272 and 700276. I don't know why they split it, other than to allow people to use Heathrow Express on a NOT LONDON ticket to Iver or Langley. I think 700272 could limit the appeal of tickets from Heathrow to Gloucester routed via Stroud.
Easement 700257 has had ONLY added. Does this affect anything?
Another 15 easements have been added, but only 700274, 700285 and 700287 are negative ones.
Is 700274 just a way to get the slow Southport-Chester trains out of the journey planners? It would seem a bit odd to focus on those two stations otherwise.
mullin
18 Jan 2010
Nope, it is designed to screw me over. I used to buy tickets from SOP to CTR and start late / finish early at PBL on them if travelling on Sundays
northwichcat
23 Jan 2009
Northwich
both directions
Likewise, this one is similar:
ATOC said:
Customers travelling from Guide Bridge to Stalybridge and beyond may doubleback via Manchester Piccadilly. This easement applies in both directions.
And this one's common sense.
ATOC said:
Customers travelling from Frodsham or Helsby via Hooton may travel via Chester. This easement applies in both directions.
But then what's the point of this one:
ATOC said:
Customers travelling Mauldeth Road, Burnage, East Didsbury, Gatley, Heald Green to Manchester Piccadilly and beyond may not travel via Manchester Airport. This easement applies in both directions.
Why would anyone even think of travelling south of the Airport to go north to Manchester?
There's a lot referring to travelling between southern stations on the Manchester/Liverpool-Crewe lines and stations on the CLC line between Liverpool South Parkway and Manchester Oxford Rd. It seems they want to make you walk a mile across Warrington from Bank Quay to Central station and not change at Liverpool South Parkway.
barrykas
19 Sep 2006
Due to the scheduling of the Airport line, it can sometimes be quicker to go via the Airport and then get an express back to Piccadilly.
On a Sunday, for example, there's a 13:03 or 13:57 from Heald Green to the Airport, then fast trains from the Airport to Piccadilly at 13:20, 13:30, 13:35, 13:55 and 14:00; but only a 13:12 or 14:12 from Heald Green to Piccadilly.
Cheers,
Barry
The direct trains rule is in the NRCoC and is unaffected by anything in the Routeing Guide.
However I do not believe it is valid to take a route that is not in the Routeing Guide, and is not within 3 miles of the shortest, claiming you are on a direct train from origin to destination, and then not actually stay on the train to the destination, irrespective of whether or not there's a negative easement, in my opinion (some people disagree).
For example an Edinburgh to Dalgety Bay is valid on the 1708 loco hauled service as this is a direct train. But I do not believe a passenger would be valid to finish 'short' anywhere on the loop.
The direct trains rule is nothing to do with the RG.
I can see the rule being clarified to say that you cannot board/alight at intermediate stations. But, sadly, I suspect some people within ATOC would rather the rule was got rid of completely. Scotrail don't seem to tell some of their guards that the rule even exists, they obviously wish it didn't. But it does, and if there are any plans to remove it, we need to campaign against that.
northwichcat
23 Jan 2009
Northwich
Cheers,
Barry
I actually misread that one so it does make sense on re-reading.
It is only for Southport or Meols Cop to Chester. It doesn't apply, for instance, for Mouldsworth to Southport where on a Sunday it would be faster via Manchester and a break of journey would be permitted.
Merseyrail did do a promotional fare of £2 for Chester-Southport on Sundays last summer, maybe too many people tried to use them on the Northern services.
For CTR to PBL you can split at Frodsham to save over paying the CTR to PBL fare.
dvboy
6 Sep 2011
700275 Customers travelling from Canley, Tile Hill, Berkswell, Hampton-In-Arden,
Birmingham International, Marston Green, Lea Hall and Stechford to Aston in
possession of tickets routed "Any Permitted" may travel via Birmingham New
Street. This easement applies in both directions.
This one seems entirely pointless.
exile
16 Jul 2011
The "not Liverpool South Parkway" ones are extremely annoying. Do they also apply to people who can't walk? Why spend £32 million on an interchange and prevent people using it?
OwlMan
25 Jun 2008
dvboyQuote:
Response deleted as easement was misread.
dvboy
6 Sep 2011
Why? Birmingham does not pass the fares rule for some journeys from these stations meaning that without this easement you have to travel via Coventry. (e.g. XC stations towards Southampton or via Nuneaton) This easement allows travel via Birmingham.
Is it the way I am interpreting the easement then, as it is quite specific in which stations it applies to - you wouldn't go via Coventry to get from Canley to Aston for example.
OwlMan
25 Jun 2008
Sorry I misread the easement, I assume that the on-line booking sites have the Stechford - Aston direct line as the shortest route (it is the booked route of some sleepers)
SickyNicky
Verified Rep - FastJP
8 Sep 2010
Ledbury
Yes - I can confirm that the direct line is considered the shortest route in the booking engine's data. The route via Birmingham would fail without an easement because it's more than 3 miles over this "shortest route".
However, I suggest that the easement should read "to or via Aston" since "to Aston" still leaves no permitted route for the booking engines to stations past Aston.
Having said that, the booking engines (at least WebTIS) currently allow these journeys via New Street, presumably via a patch or a less strict implementation of the shortest route + 3 rule.
sheff1
24 Dec 2009
Sheffield
The question of walking has been debated many times, but without a consensus being reached.
I use tickets based on my belief that the NRCoC wording means that a walk between stations cannot be mandated by the RG. Others disagree.
I have never actually had need to outline my reasoning to a ticket checker as all my tickets have been accepted without query.
