I think Edinburgh drivers can get as far as York, if the service is disrupted.
They will either sign it or not, nothing to do with disruption. If they sign to York then they will need enough work in the roster to maintain their route knowledge.
Controversial thought..(only a thought)
Is York not a better Half way point for a drivers depot instead of having Newcastle and Doncaster one?? Edinburgh to York then York to Kings Cross similar to Virgin having Glasgow to Preston to London
Problem is the depot. It makes sense to have crew at Newcastle because of Heaton.
Some services also change crew (not sure about drivers) at Berwick. I'm sure the 1600 KGX-ABD is one of these services.
I know London men sign to Newcastle so I would be highly surprise if Newcastle men did not sign to London. I'd imagine a lot of turns would be Newcastle - London and back, or 2 Edinburghs.
but need 12 hours from when you book off to when you book on
I'm assuming this is a union agreement, and not legislation?
Prior to privatisation you would not need as many lodging turns as today. This was because the depots at Inverness, Perth, Aberdeen, Edinburgh, & Newcastle would probably be able to cover almost all work and still allow the traincrew to return to their home depot at the end of their shifts.
However after privatisation due to the limited number of through EC services North/West of Edinburgh it does not made sense for EC to have full Traincrew depots at these locations and therefore more driving lodging turns came into existance for these routes. (Mainly taxis to/from Glasgow Central prior to/at the end of each shift for this route).
I believe (on hearsay evidence though) that originally GNER Edinburgh drivers refused to do lodging turns so Newcastle picked up the work. Things change however and Edinburgh now wants the work back (although you could say they never had it in the first place?). Newcastle depot is resisting this however.
4 driving links.
North Link
South Link
Heaton Relief Link
and Lodge Link.
Another possible historic reason could be mileage payments?
Could you explain the term "driving links" and describe the four you mention?
I'd love to work for East Coast at Edinburgh as a driver at some point but I wonder if working for XC would be more varied?
Doubtful as XC at Edinburgh sign pretty much the same stuff as EC!
As a matter of interest does a driver have to have driven every permutation of a route when signing for it. I'm thinking of multi track locations and approaches to large Stations where the possible routings can be many and varied depending on circumstances.
Also in my time commuting (on what is now Southeastern) from Ashford there were a few occasions when diverted to other routes along bits that never saw timetabled trains (Petts Wood to Bickley Jnc fast lines). This happened on a few occasions upon diversion to Victoria after problems on the Charing Cross line. The trains never slowed on the diversion. I realise east Kent (Ramsgate etc) drivers have probably signed both routes to London (Chatham to Victoria and Ashford to Charing Cross) but how many would have actually driven that short 1/2 mile section that were only used by Eurostar before the move to St Pancras. Was this a case of nightime ECS movement to retain route knowledge?
Again back in my commuting days, the last train to Ashford (11:30 ex Charing Cross) was often pathed on the UP line between Paddock Wood and Ashford as the engineers got to work on the down line. Would a driver have to have physicaly driven this "wrong line" to be able to sign it. (note: The line is bi directionaly signalled).
