East Midlands Railway livery and station branding
OTRail
14 Jul 2019
How come the ex-EMT mk3s are being used with the ex-LNER power cars as opposed to the LNER mk3s?
Mugby
25 Nov 2012
Derby
The 180s which have stood on the curve opposite the old PSB at Derby for several months have now been moved.
Two sets have been shunted down to the bottom end of Etches Park, alongside the main line.
The Hull Trains name is still clearly visible even though the lettering has been removed.
43055
8 Mar 2018
Two sets are in the shed while the other two are outside alongside the mainline. I'm sure the two sets that are outside where running yesterday as well.
WillPS
18 Nov 2008
Was refurbishment work always expected to be needed for the EC Mk3s? I thought the only reason they were being taken on was because they were ready to go (and a bit more compliant)
43055
8 Mar 2018
They are not being referbished that part is ok. Mechanically they are in a bad way which is what is taking the time to get the sets out as they need to be sorted first.
OTRail
14 Jul 2019
Seems a bit of a waste considering the current HSTs are due to be replaced in a few months. May as well just have kept the ex-EMT units and extended the derogation...
Ethan1852
10 Jul 2020
Leicestershire
Has the mark 3 Coaching stock that was used by the withdraw Class 43 Locomotives also been withdrawn or been stored. I know that Ex LNER Class 43 Locomotives are using some of the old stock so I am unsure of what has happened to them.
Domh245
6 Apr 2013
nowhere
I think they're all still in use currently, the ex LNER rakes should have replaced them, but as discussed on other threads they require an awful lot of work to enable them to be used. Only one ex LNER rake is in use AFAIK
43 302
25 Oct 2019
Only NL51 has entered service so far, and it hasn't been out a lot. NL06 & NL07 (44044 stored at Long Marston) have been scrapped.
raetiamann
15 Sep 2013
I wonder where that leaves the 180 sets. I don't believe any EMT branding applied as yet to them.
OTRail
14 Jul 2019
I can imagine the same will happen to them as with the ex-GA units - some (if not all) receiving EMR’s interim livery.
43055
8 Mar 2018
I would say some sort of branding will be applied in time, most likely like the 156s. I don't think they will be in service until the end of the year at least.
OTRail
14 Jul 2019
Driver training’s apparently commencing next month, with the aim of getting them into service by the December 2020 timetable change.
Scott1
29 Apr 2015
Is the purpose of 180s just as additional capacity or are they going to replace the HST sets?
They were to replace some HST sets by working in pairs, though with the reduced passenger numbers that could change I imagine.
Domh245
6 Apr 2013
nowhere
My understanding is that they were replacing the ex-GC 'short' sets like for like - no need for running in double, and 1.5 diagrams between 4 units should be about manageable for them!
Murray J
10 Aug 2019
East Grinstead
I mean to my knowledge the only ex GC set out usually is DY23 (43480+43484), going by the HST allocations that come out most days, although not sure if this was different prior to a few months ago.
Domh245
6 Apr 2013
nowhere
There were (and are) two diagrams for the short sets - one does DBY>STP>NOT>SHF>STP>COR>STP>DBY and the other does NOT>STP>NOT
43096
23 Nov 2015
There’s only one diagram currently as far as I know.
From HSTgen it works:
1C98 0731 Derby - Pancras
1D21 1005 Pancras - Nottingham
ECS Nottingham - Sheffield
1C52 1400 Sheffield - Pancras
1F72 2031 Pancras - Derby
Domh245
6 Apr 2013
nowhere
Presumably that second one has been moved over to a 222? I certainly would expect that as services and passenger numbers continue to pick up they would revert back to those diagrams using the short HSTs/180s?
43055
8 Mar 2018
Ok that make sense.
That's the first I've heard about working in pairs.
