East Midlands Railway using two coach trains on Crewe to Derby line
Discussion in 'Allocations, Diagrams & Timetables' started by thenorthern, 15 Jan 2020.
  1. thenorthern
    thenorthern Established Member
    3,566
    27 May 2013
    Over the past few weeks I have noticed East Midlands Railway has started using two coach trains on the Crewe to Derby Line rather than the old system which was to use 3 single class 153s throughout the day until the early evening when one of them would be replaced with a Class 158.
    Has there been an allocation change and will this be permanent?
    Rail Forums
  3. Bletchleyite
    Bletchleyite Veteran Member
    46,727
    Up and down the south WCML (mostly)
    Unless there is a dispensation, Class 153s are not, because of PRM-TSI, allowed to work alone any more[1]. So this is indeed permanent.
    Long term it'll be 2-car Class 170s.
    [1] You could fit a PRM toilet and wheelchair spaces but then you'd lose half the seats. You could remove the toilet, but that would be, er, inconvenient.
  4. thenorthern
    3,566
    27 May 2013
    There were rumors that Class 153s were going to be converted back to Class 155s a couple of years ago which would make sense with PRM-TSI rules.
  5. PHILIPE
    PHILIPE Veteran Member
    11,115
    14 Nov 2011
    Caerphilly
    Rumours scotched straight away. Too costly for one thing
  6. WillPS
    WillPS Established Member
    2,353
    18 Nov 2008
    Sheffield
    No reason they couldn't be semi-permanently coupled with the cabs in disuse though, like all the non-150001/150002 3-car 150 formations there have been past and present.
  7. Bacon_BMW
    Bacon_BMW Member
    10
    27 Oct 2019
    Pittsburgh, USA
    I’d think the cost would be worth it for at least a few of them just for a little more freedom.
  8. Andy Pacer
    Andy Pacer Member
    475
    11 Jul 2017
    They do, in fact, have dispensation on the Crewe to Derby route, but they had also said that from the December timetable change there shouldn't be any scheduled 1 car trains in operation, so likely a bit of both.
  9. Qwerty133
    Qwerty133 Established Member
    2,109
    7 Oct 2012
    Leicester/Sheffield
    There is a dispensation in place for the Crewe route, and even if there wasn't there appears to be a 2x153 formation on a route without dispensation this afternoon.
  10. RealTrains07
    RealTrains07 On Moderation
    1,407
    28 Feb 2019
    I thought the rules were the 153s could continue to operate attached to a unit already PRM compliant but then again not enough 156s to go round unfortunately
  11. Bletchleyite
    46,727
    Yes, that's right, they can be coupled to one or more PRM compliant units. Though as others have said it seems there is a dispensation here.
  12. Bacon_BMW
    Bacon_BMW Member
    10
    27 Oct 2019
    Pittsburgh, USA
    How about ECS moves? Can they be used as single cars or sets of just 153s if they are out of service? I would think that would make sense.
  13. Ianno87
    Ianno87 Established Member
    6,026
    3 May 2015
    Undortunately, the people who actually have to pay for it don't.
    Don't see why not...but wouldn't often be of any usefulness.
  14. Lincoln
    Lincoln Member
    154
    13 Jan 2010
    Eastern
    Peter Wilkinson, the chap who is best friends with many a train driver, has had his dispensation letters posted on the DfT website. For completeness they are also attached to this post.
    The only issue at hand is when they are run in passenger carrying service. They can be considered no different to a coal wagon when run as empty stock on their own, as nobody who the regulations apply to will be on board.
    The dispensation applies to: 153302, 153308, 153311, 153313, 153318, 153319, 153321, 153355, 153357, 153368, 153372, 153374, 153376, 153381, 153382, 153383, 153384 and 153385.
  15. vlad
    vlad Member
    432
    13 May 2018
    Hang on - 2-coach trains permanently on the Crewe to Derby line? o_O
    This has changed what was usual so much that it must be ushering in the end of the world, or something similar....
  16. InOban
    InOban Established Member
    2,417
    12 Mar 2017
    Considering that 40+ years ago when my wife and I were users of that service, heading to Derby from Glasgow, it was a busy two coach train....
  17. Bletchleyite
    46,727
    40+ years ago it would presumably have been a 2-car heritage DMU, with 18m vehicles, 3+2 bench seating and a third of one of them taken up with a guard's van. So a modern 2x23m unit offers a whackload more space even if not substantially more actual seats!
  18. Baxenden Bank
    Baxenden Bank Established Member
    1,594
    23 Oct 2013
    Yes.
    Eventually Greater Anglia will have some trains which work properly, allowing release of their 156's. The 156's were meant to transfer to EMR to replace 153's at the turn of the year. Had all been well, no 153's would have been operating singly now.
    I fail to get excited about the use of double 153's. Twice as many cramped seats in a decrepit, mechanically life-expired wheelbarrow is no great improvement. Fasten them together permanently, remove several rows of seats and re-space the remainder and they may be worth taking a trip on.
  19. Bletchleyite
    46,727
    At least if you have two 153s there are then 24 seats it is possible to sit in rather than 12. (There are 6 tables per coach, right? These are so tightly spaced that only 2 out of the 4 seats are useful, though, ideally people sitting diagonally opposite one another).
  20. Failed Unit
    Failed Unit Established Member
    7,493
    26 Jan 2009
    Central Belt
    Yep same in Lincolnshire. 2x 153 or 156s on all routes. But the 153s unfortunately are here to stay while EMR bail out greater Anglia. Personally I would have demanded the 156s and sent the 153s to them. (Unless driver knowledge has lapsed).
  21. Sprinter107
    Sprinter107 Member
    300
    26 Mar 2019
    It wouldve been a three car class 120. Working a Crewe to Lincoln train.
  22. Merthyr Imp
    Merthyr Imp Member
    306
    24 May 2016
    Merthyr Tydfil
    For example:
  23. ag51ruk
    ag51ruk Member
    601
    29 Oct 2014
    With First Class almost until they were replaced by Sprinters
  24. Merthyr Imp
    Merthyr Imp Member
    306
    24 May 2016
    Merthyr Tydfil
    I used to travel on them regularly between Nottingham and Lincoln and the First Class area had been downgraded for some years before they were replaced, although I can't remember exactly when. I would always try if possible to make use of the 2+1 former First area with the more comfortable seats.
    Also, some years before the end of them the centre trailer cars had been replaced (again, I can't remember when) by Metro-Cammell trailer cars - and I used to try and avoid them!
  25. OrangeJuice
    OrangeJuice Member
    87
    4 Jun 2018
    From many years of commuting Crewe to Derby there are 2 decent tables per coach and in most (although annoyingly not all) one airline row of 'extra legroom' seats near the 'wheelchair' area that are acceptable
  26. ashworth
    ashworth Established Member
    1,237
    10 Sep 2008
    Nottinghamshire
    I remember them so well from the the 1970’s when I was at college and used to travel regularly between Lowdham and Derby. I remember the comfortable grey seats and the orange curtains. Amazing that it could have been three cars in those days when today EMR are planning on mainly running 2 car 170’s and Northern are introducing so many 2 car 195’s.
    An hourly Crewe to Lincoln service which ran in those days was so much more useful than what we have today. It provided a through train from Nottingham to Crewe for connections to the North West, Scotland and North Wales. Also a useful through service from Lincoln to Derby for connections to Birmingham, Bristol and the South West. So much more useful for the people of Lincoln than the current service to Leicester.
  27. Sprinter107
    Sprinter107 Member
    300
    26 Mar 2019
    Yes, some of those Etches Park 120s had their centre cars replaced with Metro Cammell class 101 cars, but not all of them did. It was about 1983 time I think. I don't blame you for avoiding them. There was just no competition between a seat in a class 101 car, and a seat in a class 120 car. Class 120 beats a class 101 everytime.
  28. Bletchleyite
    46,727
    3 X 18 = 54
    2 X 23 = 46
    Shorter, but not that much shorter.
  29. Sprinter107
    Sprinter107 Member
    300
    26 Mar 2019
    3 x 19.5 = 58.5
    2 x 23 =46
    The 120s were on a longer underframe.
  30. superkev
    superkev Established Member
    2,009
    1 Mar 2015
    west yorkshire
    A 3 car 101 beats a 120 on hills - hmm Comfort but grossly underpowered with same engines but longer and heavier (steel rather than aluminium). Non of them beat my favourite dmu the Rolls Royce powered Class 110 calder valley units. Thread getting off topic.
    K
  31. 30907
    30907 Established Member
    8,007
    But from memory had only 120 seats in second
Share This Page
