East Suffolk bustition
21 Jul 2020
Brampton
The East Suffolk is shutting between Lowestoft and Saxmundham for two weeks from the 24th this month. Will buses take folding cycles? GA told me that minibuses will run from Brampton Station but that they don't know where they will run to. Do any of you know?
_toommm_
8 Jul 2017
According to National Rail Enquiries (NRE), Greater Anglia will take folding bicycles on replacement buses:
Buses will run from Brampton to Saxmundham in one direction (stopping at Halesworth and Darsham on the way) and from Brampton to Lowestoft in the other (stopping at Beccles and Oulton Broad South on the way). At Saxmundham, you then have a train every hour on to Ipswich. The link to the times at Brampton are below:
As for where the buses pick up, I'm not too sure. NRE normally indicates the pickup point but they've not included that info on their website, instead pointing you to ask at an available help point once at the station.
21 Jul 2020
Brampton
Thank you. I can't get any more than that out of GA. Their customer care is the worst I've known since I started going on the line in 1988.
_toommm_
8 Jul 2017
I’ve just had a look on Google Maps, and I’d presume the buses go from the two bus stops outside the station (it’s not quite as rural as I thought it was), and I’m guessing there’ll be a poster detailing rail replacement bus pickup points at the station.
21 Jul 2020
Brampton
You'd think so, but no. The buses always go on the A145 two miles away from the station. I'll check on the station board tonight
30907
Seems odd that there is a minibus serving Brampton if it is using the same route as the main bus - but I don't know the area so...
21 Jul 2020
Brampton
What they did one weekend was have a minibus bringing us to the main bus. The station is away from the village by two miles. They thought of building the station in the village but ended up building it by the railway line.
