When the East bit is done I think it would make more sense to run Oxford-MK, Cambridge-Bedford-MK, and Marylebone, High Wycombe, Aylesbury MK than run through. By that time HS2 will be open and there will be more paths between Bletchley and MK.
I also think a direct route to Cambridge from Bedford is a mistake, the rejected option for a curve at Millbrook onto the MML to Luton Airport then new line to the top end of the Hertford Loop at Stevenage then onto Cambridge via Royston, would have given far more journey and interchange opportunities.
A Cambridge, Royston, Baldock, Letchworth, Hitchin, Stevenage (intercity interchange) Luton Airport (intercity interchange), Luton, Flitwick (for Bedford), Woburn Sands, Ridgmont, Bletchley, MK train..
is going to carry far more passengers than a
Cambridge, Camborne, Interchange north of Sandy with no intercities calling, Bedford, Ridgmont, Woburn Sands, Bletchley, Winslow, Bicester, Oxford train.
Yes the direct route is quicker but most of the usage will be intermediate journeys and in any case the time spent grinding around at 10mph in the Bedford St Johns area will wipe out a lot of the gains the direct route has over the rejected alternative via Luton and Stevenage.
The latter would also have given new journey opportunities like Thameslinks running London-St Albans, Stevenage, Peterborough or MK to Hertford and Stanstead and the possibility of an underground station directly underneath the main terminal at Luton Airport.
