Class 170101
- Joined
- 1 Mar 2014
- Messages
- 7,942
However there's actually quite a lot of flexibility, as EWR could take power from the WCML, MML and ECML where they meet, and extra feeders could be built alongside those main lines instead (or perhaps the existing ones could be upgraded). Slightly more awkward if EWR remains separate from NR, but it ought to be possible to include some kind of meter at the connections so NR can charge EWR for what they use.
GOB was wired this way and if it is possible draw feeds from GWML, WCML, MML and ECML then thats all to the good but I would have thought the distances between each of them might be too great and it may also require substation renewal of existing sites to boost supply as more trains will need to be covered from existing sites. It should be noted that the GOB wiring I believe only allows two electric locomotives to operate at any one time due to no independent supply on the line.
Metering is used on many trains now especially newer ones so as to allocate costs more accurately.
