ECML Blocked - Wires down at Retford
nickswift99
7 Apr 2013
Currently trying to get North but not going anywhere. RTT showing lots of southbound services cancelled. Long queue of northbound services beyond Peterborough.
83G/84D
28 Oct 2011
Cornwall
It would appear that 0708 King's Cross to York was involved (91110).
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
I'm on 1S09 which is the 09:00 ex Kings Cross to Edinburgh, we're currently sitting at Peterborough held in platform two (should have departed here 09:46). Currently showing 15 overdue.
1N09 which was the 08:30 ex Kings Cross to Newcastle is also sitting here at Peterborough, held in platform four (should have departed here 09:16). Currently showing 56 overdue. It arrived on time!
No estimated times for departure.
Update: Passengers on 1S09 have just been transferred onto 1N81 (09:08 ex KGX), HST service to be diverted. Passengers for destinations north of York to change there for connections. I'm very lucky to have legged it across the bridge to 1N81 and have managed to get a seat. It also seems that First Class complementary service has been withdrawn on 1N81... Menus have just been collected! Diverting to avoid Retford. First Class declassified on 1N81.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
1D06 is showing 112 late still at Peterborough; 1N81 currently diverting via Lincoln having just left Newark North Gate.
Master29
19 Feb 2015
Must be OK now as all seems fine at Skelton Bridge on York railcam
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
The issue isn't at York.
Trains are unable to run between Retford and Doncaster until approximately 14:00. "Trains between Grantham and Doncaster will be diverted via Lincoln Central or cancelled." Rail replacement bus services are running between Retford and Doncaster. (Source: NRE)
Where possible services are being diverted via Lincoln Central, else services are being cancelled.
Major disruption to services is expected until the close of service.
TP
NeilWatson
20 Jan 2013
Is traffic being diverted at Doncaster via Spalding, to Peterborough and onwards where stock permits?
96tommy
18 May 2010
HST's only between Donny and Kings Cross, via Lincoln one presumes. Hasn't been a NB since around 09:00.
Causing train 91110 just left Donny behind 67023 in service to York
66Yorks
17 Apr 2015
Does anyone know the cause of the wires coming down? It seems to occur a lot in that region.
Conventional wisdom is that it is the use of headspans rather than portals. So when one wire comes down it brings the whole lot down.
66Yorks
17 Apr 2015
Apologies but could you explain the use of headspans?
Does that imply a single column rather than a portal frame carrying the wires?
dgl
5 Oct 2014
Masts each side with the wires attached to a wire that is stretched between the masts, damage that wire and it all comes Down.
Crossover
4 Jun 2009
66Yorks
17 Apr 2015
Many thanks, explains everything. :D
Is it possible therefore that a train can bring the wires down or is it generally a failure within the OHLE structure.
Domh245
6 Apr 2013
nowhere
The wires won't usually fall down by themselves, so it tends to be the passing of a train that initiates the failure. The problem comes from that design (mk3) seemingly being more prone to failure than others, and of course, there is then the problem that being a headspan - once one wire goes down, they all go down.
gavin
25 Dec 2006
@Virgin_TrainsEC
Damage to wires worse than expected. Lines affected will be blocked until at least 1600.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Really frustrating sitting on a 120 Min late Aberdeen service which is very overcrowded when I watched an empty VSTP 1F15 leave York carry little other than fresh air… hindsight is a wonderful thing, but I wish I had travelled to York on 1N81 rather than bailing at Doncaster as we were advised to. We've just left Newcastle with 1F15 ten minutes ahead of us.
By the time I realised that 1F15 was sitting there and it was the service shown on the Live Departure Boards it was way too tight to risk a connection.
Starmill
18 May 2012
Bolton
Virgin Trains East Coast said:
Overhead wire problems near Retford mean that trains will be unable to run between Retford and Doncaster until approximately 15:00.
Buses are running between Retford and Doncaster.
The line is expected to reopen at 15:00, however delays can be expected until the end of service.
Alternative travel options
Grand Central passengers may use:
East Midlands Trains between London St Pancras International and Sheffield
CrossCountry between Sheffield and Doncaster
Virgin Trains East Coast, Northern and TransPennine Express on any reasonable route.
Hull Trains passengers may use:
Virgin Trains East Coast on any reasonable routes.
Virgin Trains East Coast passengers may use:
CrossCountry between Sheffield and Newcastle
East Midlands Trains between London St Pancras International and Sheffield. Details of alternative routes via London St Pancras International can be found here.
Great Northern between London kings Cross and Peterborough
TransPennine Express between Manchester and Leeds / York / Newcastle
Virgin Trains services between London Euston and Scotland / Manchester. Details of alternative routes via London Euston can be found here.
Details of all alternative routes available can be found here.
Advance ticket restrictions have been lifted for the rest of the day and passengers with tickets dated for today may travel on tomorrows services.
You can follow this incident using the hashtag #Retford
If you experience a delay in completing your journey because of this disruption, you may be entitled to compensation
www.virgintrainseastcoast.com/travel-information/travel-alerts/#serviceupdates
sarahj
12 Dec 2012
Brighton
Wires come down for 2 main reasons. Wind, or trains making the wires swing, panto then looses contact and gets caught up, then pulls it all down.
Or. Panto. Worn or damaged carbon strip, gets caught.
Modern systems should have a panto damage kit, where, when it goes wrong, it drops.
Here is a video of a panto being damaged and then trashing the overhead. (in germany)
https://www.youtube.com/watch?v=XgCPPeYmyKw
10 Mar 2015
I was working on 0803 IPS-PBO, we were ourselves 20 late due to track circuit failure at Thurston, spent the whole trip to PBO sorting out northbound connections because there was "no way" people were going to make the 0952 Leeds :lol:
As far as I'm aware it was still waiting to access PBO when I rolled back into Ipswich! Oops. At least they all made the connection!
nickswift99
7 Apr 2013
So having had a complete failure to get to Leeds today, there's a few things I'd like to share.
Firstly, every rail employee I met - VTEC, Hull Trains, Northern Rail and East Midlands Trains were brilliant. In spite of very difficult circumstances it was a pleasure to see everyone trying their best. If you were involved today, please accept my thanks from a grateful passenger who in spite of your best efforts never got to his intended destination.
To VTEC, your online train progress web page really sucks. Sat outside Peterborough for over an hour with a web page that says there are no disruptions really isn't good enough in the 21st century. As often happens in a major failure, it was evident that the people on the ground were working in an information vacuum.
Finally, the Hull Trains person at Doncaster was really on the ball. Unfortunately all the trains he was expecting didn't turn up but he was extremely proactive. If anyone knows who he is or can at least tell me how Hull Trains might identify him, please PM me as I'd like to write to his employers.
