... has been published today.
The refresh to ECML:Northumberland updates the route as follows:
openBVE: I've sorted out all the transparency issues, so the route is now drivable in openBVE, without producing error reports (unless there are errors in the trains - my machine tells me I'm missing a train sound file). BUT openBVE users should bear in mind that this route was written for BVE 4, and if you use exterior views of trains, you may see gaps in the scenery.
Scenery: MetroCentre has been completely rebuilt to be more prototypical. Span wire overhead has been modified to make it look more realistic. Speed limit signs have been built to the correct size - probably too large for areas of restricted clearance, but I'm not going to lose sleep over that at the moment. Adam's new Voyager passing train objects have been introduced, and very fine they look, too. Signal posts now have a telephone which is nearer to the correct size (except on repeater signals!).
Routes: The empty coal train now terminates at Berwick loop. One of this year's December Sundays only Northern Rail services to Alnmouth has been modelled, using Wooden Gate crossover to reach Alnmouth's Platform 1.
I am, as ever, grateful to all those who have contributed objects and helped with the testing. If you spot any errors, please email me!.
Work will continue on the update to Tyne Valley over the Christmas period.
Regards
eezypeazy
Regards
eezypeazy
