I know that it is very common for BT fibre to be cut by thieves looking for copper. One of the worst cases was one of the sub-sea cables out to the Isle of Skye. The engineers could only work on the cable for a few hours at low tide.I forgot to mention: our Train Guard said he'd heard but wasn't sure that the cables in this area are all fibre optic, and as such, practically worthless! Could be hearsay, dunno. Still the point stands that's thousands of pounds for either no or very little gain.
I wouldn't be surprised if similar (maybe minus the Atlantic ocean!) happens on the railway.
I travelled on 1Y03 (0445 ex-Newcastle) and we were talked by three signals before the TBW was implemented.
Broadly speaking, it does consist of a handsignalman at either end of the temporary block section, each working to the instructions of the signalman (or signalmen!) controlling the area. A numbered ticket is issued to each driver at the entry to the section, detailing which signals can be ignored and which must be obeyed - that ticket is then surrendered at the exit signal. The purpose of the exercise is (usually) to avoid having to talk past each signal individually.
Times like this I wish HT had 30 min delay repay rather than 60 min.
When our train services are disrupted or delayed by 30 minutes
or more, despite our own best efforts we will also provide
compensation.
All ticket holders may apply for compensation, irrespective of the
cause of the delay. The level of compensation is outlined below:
30-59 minutes compensation of at least 50% of the cost
of the single ticket or 50% of the relevant journey portion of a
return ticket.
60-119 minutes delay compensation of at least 100% of the
cost of the single ticket or 100% of the relevant journey portion
of a return ticket.
120 minutes delay or longer compensation of at least
100% of the cost of the single ticket or at least 100% of the full
return ticket.
