Edinburgh - London sleeper 27th June
Discussion in 'Fares Advice & Policy' started by Failed Unit, 27 May 2010.
Thread Status:
  1. Failed Unit
    Failed Unit Established Member
    7,493
    26 Jan 2009
    Central Belt
    Can anyone tell what has happened to the 2326 Edinburgh - London service on the 27th June. (Sunday night) I have been trying to book it online but search engines can't find the train. Is it full already or do we have a fault with the booking system this evening? I have also tried booking Stirling - London on the same evening again the website gives me an error. Confused? :oops:
    Rail Forums
  3. rail-britain
    rail-britain Established Member
    4,104
    12 Aug 2007
    I suspect it is full
    Also note the train is diverted and arrives into London later, but this later arrival is in the timetable
    Ironically, there are also still berths on the Glasgow (which joins the Edinburgh)
    You could therefore also travel on this from Glasgow or Motherwell
    There are however still berths on the Aberdeen
    This is showing as 23:36 Edinburgh - Inverkeithing, 00:12 Inverkeithing - London Euston (although that is just 14 minutes at Inverkeithing)
    There are also still berths on the Inverness
    This is showing as 22:36 Edinburgh - Falkirk Grahamston ,00:02 Falkirk Grahamston - London Euston
  4. Failed Unit
    7,493
    26 Jan 2009
    Central Belt
    Thanks, looks like a trip to Glasgow then and double back. The highlands sleeper arrives too late for me. Sold out this far ahead. I wonder if people are taking the safe option over air?
  5. Oliver
    Oliver Member
    464
    17 Aug 2007
    I think they often sell out well ahead; the capacity of a sleeper train is quite small compared to a day train or an aircraft.
  6. Failed Unit
    7,493
    26 Jan 2009
    Central Belt
    I normally only book the week before and this is the first time I have encountered a sell out this early. I admit that you don't have many spaces but for the seated to be all gone as well is rare. On weekdays I often book they day before. Edinburgh can be full. Glasgow rarely is.
  7. 87015
    87015 Established Member
    4,381
    3 Mar 2006
    GEML/WCML/SR
    Even if sold out it should show on journeyplanners, sounds like itsnot been uploaded to the systems correctly yet.
  8. rail-britain
    4,104
    12 Aug 2007
    It does show on the journey planner
    It looks like the online interface does not recognise that the Glasgow is also picking up and joining with the Edinburgh
    I therefore suggest you phone ScotRail and check
    The first Sunday on which I can find availability is 12 September (and from memory this when the diversion ends)
  9. jamesontheroad
    jamesontheroad Established Member
    1,424
    24 Jan 2009
    What is the total capacity of the Lowland sleeper? And is it equally spread between Edinburgh and Inverness? I could probably count carriages next time I'm in GLC late at night, but there's no way of telling second from first class carriages outside.
  10. Failed Unit
    7,493
    26 Jan 2009
    Central Belt
    Glasgow and Edinburgh are the same. Normally seated lounge the 6 sleepers. The first 2 are first class. Inverness is also 8 car. Fort William and Aberdeen vary depending on the time of the year. Fort William can be 2 sleeper. Aberdeen 4 sleepers. Both have lounge and seats but the fort William seats detach at Edinburgh.
  11. EltonRoad
    EltonRoad Member
    1,029
    2 Jun 2009
    Kendal
    If you click on the ScotRail web site and Buy Train Tickets, it says "We are currently waiting on Network Rail to correct a number of errors on some Sleeper services.These services will be available as soon as possible. Please call 08457 55 00 33 if you are unable to find the Sleeper service you are looking for." I'm sure this specified Sunday night sleepers, until recently.
    Also, FW sleeper is 2 x sleepers except Friday nights down and Sunday nights up, summer only, when it takes one of the 4 Aberdeen sleepers (coach E, standard class). On these nights they often don't sell the cheaper of the two tiers of fares in both classes. (Maybe I should get out more?)
  12. Oliver
    Oliver Member
    464
    17 Aug 2007
    I think a sleeping coach has 12 cabins, therefore holds between 12 and 24 passengers, depending on how many are sold for single or double occupancy. The seating coaches obviously carry more. So the Aberdeen portion handles 96 sleeper passengers max; fewer than most planes.
  13. A60K
    A60K Member
    1,030
    26 Jun 2008
    Kilburn
    I think it's 13 cabins for the SLE, 12 cabins plus attendant's pantry for the SLEP - or has the disabled cabin conversion a while back changed this?
  14. caughtonatrain
    caughtonatrain Member
    66
    28 May 2008
    Just the other day I had the same problem with a Sunday sleeper in early June - not coming up on the booking engines. The ScotRail call centre took my request and phoned me back less than 24 hours later confirming my berth. I suspect berths WILL be available for the journey the OP wants - just give them a call.
  15. Failed Unit
    7,493
    26 Jan 2009
    Central Belt
    Have done and got the tickets I wanted, I wonder if Scotrail are losing potential customers because of this however. Thanks everyone for the advice.
  16. rail-britain
    4,104
    12 Aug 2007
    Glasgow : 22 First Class and 88 Standard
    Edinburgh : 22 First Class and 88 Standard
    Aberdeen : 11 First Class and 66 Standard / 11 First Class and 44 Standard
    Fort William : 11 First Class and 22 Standard / 11 First Class and 33 Standard
    Inverness : 22 First Class and 88 Standard
    The ratios of First Class can be varied and I have shown the typical allocation
    On the Fort William that is the MAXIMUM number of First Class, very often it is only 5 First Class with 34 Standard or 45 Standard (ie the south coach has both)
    As above, you can see the Edinburgh and Inverness have similar allocations, but they are different trains
    Again, the number of First Class can vary
    When I travelled on the Inverness - Euston sleeper last year it had just six First Class the other 16 berths were booked for Standard solo
  17. Sleepy
    Sleepy Member
    981
    15 Feb 2009
    East Anglia
    :lol: At last - someone else on here obsessed with Sleepers (though more FGW in my case !) LOL
  18. rail-britain
    4,104
    12 Aug 2007
    Already mentioned, see post 9
Thread Status:
Share This Page
