Hi,
I also found that the updated files went off to different places within the BVE4 Folders. The Cl66, Markinch and Object files were saved outside the 'Railway' Folder and it was a matter of cutting and pasting them into their respective folders.
I have checked out the object errors and the new Jct signals at Thornton Jct and Laurencekirk Jct (for the loop). Laurencekirk is fine but as there wasn't a correct MAS Jct signal in BVE4, Don had to make one up to the sketch that I sent him and while not perfect, the signal takes you into Thornton loop correctly.
There is still one problem in that when you jump to the Thornton Jct signal you arrive five minutes early and then depart late for the loop. This will require retiming in the Timetable Editor. Likewise the signal shows a 'lit' feather all the time until the signal clears. The feather should only light split seconds prior to the aspect clearing. The system checks the route is set & locked correctly, operates the feather, then if all is correct the signal is cleared. This I expect is another problem within BVE4 that needs sorting out, if it allows.
There are still two objects not showing correctly. Just beyond Springfield station a bank (By a stone bridge) encroaches towards the ballast and at Laurencekirk a tree and the roof of a building (on the left) out in the fields appear as 'floating objects. But, hey, two objects in such a large Route is nothing to be ashamed of, I think you will agree.
Overall Don has done a nice job on the upgrades and it remains one of the 'great' routes in BVE.
Regards.
BillEWS.
