Poolsharks1
Does anyone know if there is plans to upgrade Edinburgh waverly? I use that station often and its so depressing. They upgraded haymartket along the road and the station is an absolute pleasure to use.
Oh maybe. It would be some job to take that ramp out though.I thought there was a plan to demolish the ramp and turn the reconfigured area into another through road? Even without this 2 extra Easten Bays will be a great help and even if not fully used to start with they will be in future. I hope they will be long enough to take a 10 car IEP so that the problem of East Coast workings laying over in a through road is sorted.
Uhm... do you use the same Waverley that I use? There's nothing depressing about it - the only thing I can think of that needs some work is probably a good cleaning of the waiting room walls and ceiling (it would be great to see that artwork in its full glory) and possibly some new furniture.Does anyone know if there is plans to upgrade Edinburgh waverly? I use that station often and its so depressing. They upgraded haymartket along the road and the station is an absolute pleasure to use.
On Topic, I think the modernisation work as has been done is fine although fail to see how millions of pounds and 18 months of disruption to replace the Historic Waverley Steps with banks of cheep chinese escalaters that never work is progress?
Funny how we have different views. Perhaps that's because I've only been when the escalators are working.
I agree that it's confusing and busy, but depressing is a word I would've used to describe Waverley ten years ago.
For me there's nothing more depressing than getting on at Haymarket when all the seats have been taken at Waverley.
I think the main work waiting to be done is the extension of platforms 5 and 6, reaĺly no more than sidings at the moment, into the wasted space where the old taxi rank is. They'll be terminating rather than through however I'm sure?
I wish they'd find a more productive use for that bit of tarmac where the short stay car park used to be by the Calton Road exit. A few market stalls on a Friday isn't really it.
I believe the current buildings by platform 12 (the CS lounge) will be replaced as part of the platform works as well.
http://www.networkrail.co.uk/aspx/6403.aspxNetwork Rail said:Improving capacity by creating space for longer trains
Ten-carriage trains are being introduced on Scotland’s East Coast routes, and eight-carriage trains on the Edinburgh to Glasgow route via Falkirk. To accommodate these longer, high-capacity trains, we’ll be extending platforms 5, 6 and 12. This work is due to start in July 2016 and to be completed by December 2017.
Id have just built the new lifts, put a roof over the old steps, cleaned up the stonework and put some new lighting and CIS in there.
They're also so painfully slow that it's considerably quicker to just walk up the stairs.
Some further digging has found the actual planning applications submitted to Edinburgh City Council here a couple of weeks ago:
https://citydev-portal.edinburgh.go...s.do?activeTab=documents&keyVal=NXADCLEWJ4E00
Following the link (very interesting stuff there) shows this:
http://citydev-portal.edinburgh.gov...-04__PROPOSED_FRANGIBLE_PLATFORMS-3222321.pdf
Can anyone advise about the concept and purpose of a 'Frangible Platform'? New one for me!
Guidance on Interface between Station Platforms, Track and Trains
Page 57 of 84
Appendix B Frangible Decking at Terminal Stations
G B.1 Introduction
G B.1.1 At stations categorised as national hub (Category A) and regional hub (Category B) stations, there are some platform / concourse areas that become particularly congested for short times during peak periods. This is often the case where fully loaded passenger trains arrive at terminal stations within a short period of time and there is congestion whilst queuing to exit automatic ticket gates. In a number of cases to provide additional space for such situations a 'frangible' type of decking over the track forming the slide path behind the buffer stop has been installed (see Figure G 5).
G B.1.2 A frangible type of decking is formed from a number of decking units supported by beams. When impacted by a buffer stop the beams guide the decking units and allow them to move freely and smoothly with the buffer stop. The decking units provide a solid platform surface for people.
G B.1.3 Where this arrangement exists buffer stops are fitted with impact brackets that are capable of applying the impact loads to the decking units. These comprise of fabricated plates welded to the rear flange of the buffer stop structure at the height required to contact with and collect the decking units as they move with the buffer stop.
G B.1.4 GC/RT5033 requires energy absorbing buffer stops to be provided at terminal or bay platforms. The key requirement is that buffer stops are to be designed to arrest the full range of trains between the heaviest and lightest using a track, without risk of serious injury to people on the train. It is important that the performance of the buffer stop is not to be materially affected by the use of a frangible type of decking, so that any greater risk of serious injury to people on the train is avoided.
G B.1.5 A frangible type of decking has only been used at national hub and regional hub stations. It is likely that the use of such a system can only be justified if the safety benefits arising from having increased passenger space are greater than the safety disbenefits arising from the very unlikely event of a train impacting the buffer stop, and subsequently connecting with the frangible decking units. The factors to consider in this justification could include:
a) The safety benefits arising from having increased passenger space.
b) The safety disbenefits arising from the very unlikely event of a train impacting the buffer stop and causing movement of the decking units with passengers still on them.
c) How close the decking units will be to the buffer stop impact bracket. The greater the distance between the buffer stop impact bracket and the nearest decking unit, the less likely it is that the decking units will be affected in the event of a minor buffer stop impact.
d) If access to the area can be limited to only the busiest times, for example by cordoning off the area.
I assume the Eccesse fares will have a new home built for it? On the escalater thing Im with 90019 here. As an asside the 2 16 person lifts that were installed are well used. The escalaters should have been LU/TFL Spec.
The new East Facing bays are great news. Dunno what I think to relocating those escalaters though.
It's usually quicker to use the lift.Every time I have used Waverley since the upgrade (at least once a month) the escalators have been working and have prevented me arriving on Princes St gasping for breath . Lifts would not be able to cope with the volume of people using that exit.
I agree they are very slow. Even so, at my age, it is not considerably quicker to walk up the steps !
In the application they state that it is not an original building:Part of what is identified as 'Scotrail Offices' on the demolition plan is a rather attractive original conservatory type structure that I hope will be relocated rather than destroyed.
Part of the Scotrail First Class Lounge this is not an original building (Photo 1). The rear of the remaining part of the lounge will be reinstated with a cladding material.
Just got to that doc now and fair enough, if they say so, but it looks like it has some historical significance. It can't be more recent than 1920s by the look of it.In the application they state that it is not an original building:
Use the link in Altnabreac's post, all the documents are linked from there. Yes, the frangible platform allows shorter buffer overruns by using energy absorbing rather than solid platform construction. Similar to the use of EMAS runway overruns to provide the necessary safe stopping area when there isn't enough room for full-length runway overruns.I'm getting "document unavailable" on that one.
Is a "Frangible Platform" something that allows the buffer stop to slide back into the platform if a train hits it? If so there are some at St Pancras and Manchester Piccadilly.
Huh?
It's anything but depressing. It's got period charm. It's now much more light and airy than it was before all the work. You seem to have missed it, but it's been rare that there's not been at least some work going on at Waverleyin the last 10 years, probably because it's such a large station. And it's still ongoing - I need not repeat the platform extension works above.
It's busy, but that applies to any major rail station. People seem to find it confusing (I don't, but it's a common claim). But otherwise I do not understand why you think it would need a major refurbishment. I really don't think Haymarket is all that much better than Waverley.
A fine station. After a long journey from London you feel you have arrived somewhere really significant. Sure it is big and takes some navigating, but that is part of the appeal.
Operationally it is interesting with the mix of services, and it has one of the best waiting rooms anywhere - the Halfway House, halfway up the stairs on the castle side.
