GrimShady
- Joined
- 13 Dec 2016
- Messages
- 1,740
Why have Scotrail started using 10 and 9w for Queen Street shuttles?
Because that's what the paths they've got allows.Why have Scotrail started using 10 and 9w for Queen Street shuttles?
Thanks for that.Here’s the new gated area at platforms 6 and 7/11.
There’s a flexible sign on the concourse saying access to 6,7 & 11 is through the ticket gates.
I agree that the main signage will need to change at it won’t be correct if it’s a ScotRail service using them.
View attachment 64329 View attachment 64330
Eh? The only access for passengers now will be via the ticket gates, regardless of whose trains are in.
Not as far as I'm aware no.Is it not the case that the gates you see in the photo will be open for non-ScotRail services?
AFAIAA LNER & XC do not want their passengers inconvenienced by barrier checks so require them to be open (at least in part) whenever one of their trains is arriving or departing.
Anecdotally I have heard that LNER are quite happy with the incomplete barrier line.
The green gates are for staff access only. The barrier staff should be letting other TOC passengers through the main gate lineMy understanding from this post and I’m sure some others is that LNER don’t want gates to inconvenience passengers. Of course things could have changed since.
There may be a good explanation but at the moment I can't see how there's any excuse for getting the signs so badly wrong. Even I predicted an issue if the sign on the wall was left in place directing passengers bound for platforms 6 and 7 towards a closed gate. I hope better attention was paid to project coordination (or simply the blindingly obvious) when constructing the new platforms.Here’s the new gated area at platforms 6 and 7/11.
Neither Virgin not LNER seem to like having revenue blocks at Edinburgh, and XC don't seem to care much either way. Given that they will be running almost all of the trains from that platform, NR probably believed that the gate would be open any time the platform was in use and that the operators would prefer not to force their passengers through a pointless gate. If that isn't the way it's actually going to be operated then the sign should be changed, although I'd prefer that they actually left the gate open or installed a small gateline next to the gate instead tbh. Either way I don't think it's fair to assume that NR have messed up.There may be a good explanation but at the moment I can't see how there's any excuse for getting the signs so badly wrong. Even I predicted an issue if the sign on the wall was left in place directing passengers bound for platforms 6 and 7 towards a closed gate. I hope better attention was paid to project coordination (or simply the blindingly obvious) when constructing the new platforms.
Agree with that, Passengers just need to allow extra time for changing trains/Connections.
Perhaps there would be more pressure to staff the ticket gates if they were installed, and I think they need this gate so that vehicles can access the platform for servicing etc. I doubt they'd be left with enough room for half a dozen gates - maybe just one or two.Is there a reason they didn't put half a dozen ticket gates where the green fence/gate is? It doesn't look like the usual full height barriers so presumably there will be a risk of people trying to jump it if a train is about to depart from platforms 6 or 7.
Do you think anyone could squeeze through what appears to be a gap in the fence under the screen, near the sign for platform 6? Probably less conspicuous than vaulting the barier. As I've been laying off the pies recently I might try it myself.
You'll struggle. That gap isnt actually there.Perhaps there would be more pressure to staff the ticket gates if they were installed, and I think they need this gate so that vehicles can access the platform for servicing etc. I doubt they'd be left with enough room for half a dozen gates - maybe just one or two.
If there isn't a gap, why are there cable ties there?You'll struggle. That gap isnt actually there.
Were there...If there isn't a gap, why are there cable ties there?
I dunno. I think that pretty much proves why you can't use platform 6 without opening the gate. Spending 5 minutes guessing how you're supposed to get to a train you can see just over a fence isn't a credible customer experience, even if there are some signs.That photo illustrates exactly why people wanting platform 6 will head for the sign with the big 6 on it and the screen showing the train they want. These need to be re-positioned further down the platform so as to be less obvious to anyone in the area where the photo is taken from.
After all the money that has been spent, I really hope this is only a temporary fix and they have a better more permanent solution for that gap.Cable ties have some tape on them now.
Lots of other tape over the existing signage and the sign on platform 6 has been moved to the side.
Also, the 1630 LNER to King’s Cross is currently at platform 6 and the gate is closed.
The last section fitted only needed to be a few inches longer (or repositioned slightly) to reach as far as the section heading along the platform and then around the OHLE stanchion. I also noticed the bolted feet for that bit extend over the angled edge of the coping sections, I wonder if that’s installed exactly as designed?After all the money that has been spent, I really hope this is only a temporary fix and they have a better more permanent solution for that gap.
Why can't they be fixed? If there's a buffer run though to that extent then a bent railing is the least of the problems. In any case, using a frangible bolt would make that even more of a non-issue.Of course the railings cannot be fixed to the section to the left, as that is part of the moving deck section if ever the buffers are run through...
I hope the authorities don't get wind of the cable ties now that the tape has drawn attention to them. Someone could use these as a ladder to climb up towards the overhead electrical equipment. It could put the whole project back by years....After all the money that has been spent, I really hope this is only a temporary fix and they have a better more permanent solution for that gap.
Conceivable an overrun could cause a piece of railing or frangible bolt to hit someone?Why can't they be fixed? If there's a buffer run though to that extent then a bent railing is the least of the problems. In any case, using a frangible bolt would make that even more of a non-issue.
If there's a 500 tonne train where it shouldn't be I doubt that a 50g bolt is going to be a major concern!Conceivable an overrun could cause a piece of railing or frangible bolt to hit someone?
