Edinburgh Waverley
mralexn
2 Nov 2010
I was last at this station at the beginning of december, and remember it being a massive building site!
I will be going through the station again at the end of next month.
a few questions..
Has it changed much? (ie to date)
Would it have changed much (by the time i go there)
Is the First Class lounge worth spending the 50points on? (east coast rewards)
and what is there in the first class lounge?
calc7
8 Aug 2011
a few questions..
Every time I go there, all that seems to happen is the scaffolding has moved.
Re: the FC lounge, I would suggest getting your "friend" to sign up to EC rewards and gifting you a lounge voucher with their 100 introductory points. ;) Said lounge is pleasant (the cleaner is a lovely Scottish lady) - with a coffee machine, still/sparkling water, crisps and biscuits. Can be worth bagging a couple of snacks in case the catering on the way down to London leaves you hungry.
90019
29 May 2008
Featherstone, West Yorkshire
A large section of the glass in the roof has already been replaced, but there's still a lot to go. Waverley Steps is now closed for refurbishment as well, can't remember when it's due to reopen.
No - they might be working on a different bit of the roof, but that's about it.
pkkelly
17 Jan 2012
Waverley Steps have recently reopened - I went up the escalator and down the steps the other evening whilst waiting to change trains. (There is a down escalator too.) They are also putting in lifts around there but these do not open until later this year.
90019
29 May 2008
Thanks, I wasn't aware that they'd reopened - it's been a few weeks since I was last there.
michael769
9 Oct 2005
I pass through the station on a daily basis, and since January the rate of change in the station has been incredible. It seems that every week some new bit of scaffolding as appeared or some bit has been removed.
Currently work is ongoing to replace the floor. The work is happening in a odd piecemeal fashion with what appears to be random sections being fenced off and dug up and replaced (no doubt there is a some master plan that makes sense somewhere - probably based around the need to keep the station fully operational at all times). You will certainly find a mosaic of old, new and temporary plastic flooring in place. The new flooring is made of very large rough marble tiles that give considerably better grip in wet conditions than the old flooring.
Most of the Eastern side of the roof is done (I get a grandstand view of that side of the roof from my office) - with just a littile finishing work being carried out and some of the temporary roof has been removed in the vicinity of the Calton Road Entrance and the ends of platforms 2/3/4 making an amazing difference in terms of light. Work seems about to start on the West end of the roof, with lots of new scaffolding and fencing appearing over that side of the station.
The bridge over to Market St and the access to platforms 8/9 has been removed, and there is currently an enclosed temporary bridge built from scaffolding (not that you can tell from the enclosure) which leads to temporary stairs to 8/9 and a temporary exit to Market St al little to the west of the original. It is currently possible to see the steel superstructure of the new replacement bridge and platform access being built from the Market St Entrance.
As others have mentioned the Waverley Steps are open and the temporary access to the Princes St mall has been removed. They are currently experiencing teething problems with the escalators with at least one unit out of commission and being repaired on a weekly basis. There is also a pretty nasty drainage leak in the in the temporary joint between the new roof over the steps and the old roof which forces them to fence part off in heavy rain.
So yet it has changed loads, and will probably be different again by the time you go through.
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
. . . .and the bicycle racks have moved to the diametrically opposite side of the station! (Temporarily). From plat 11 at the west end to the eastern end of plat 2.
I like the new Waverley steps. They eliminate the ledgendary effect of channelling a phenomenal amount of wind down there, even on relatively windless days, and of course keep the rain off our heads!
[isn't this really a question for the Infrastructure forum?]
michael769
9 Oct 2005
That is not a recent change - they have been there since last spring so the OP will have encountered that during their last visit...
