Electron/Debit Cards
WillPS
18 Nov 2008
Sheffield
Just to throw another cup of water over the fire of Visa Debit validity on-board - Halifax (the last remaining Electron issuer) have now started replacing Electron cards with Debit cards.
My girlfriend received a replacement card 2 years ahead of expiry today with a note saying that the existing card will expire ahead of its stated validity. The new card has raised details and no "ELECTRONIC USE ONLY" or similar, but the letter accompanying the new card states in a small note:
You need to make sure you've enough money in your account so everything will go through automatically. If there isn't enough, you shouldn't be able to buy the item or withdraw cash. Your new card is designed to make sure you can't spend money you don't have.
So I take from this it will not function on board - however nothing on card states this, so that makes at least 3 banks issuing Visa Debit cards which ATOC et al. refuse to make amends to authorise.
island
30 Dec 2010
Sounds like it.
This will be interesting for the airlines etc. that give exemptions to surcharges for Visa Electron cards as Halifax was the last UK mainstream bank to issue them.
GadgetMan
9 Jan 2012
Depends on the TOC. If there is nothing on the card to say electronic use only and it gets declined (which it will), then we can ring an automated Merchant services number and get authorisation over the phone to override Avantix.
Zoe
22 Aug 2008
But you can't do this with a card marked electronic use only?
headshot119
31 Dec 2010
Dubai
Is that a rail only policy? There's nothing in the document where I work to say I can't get voice authorization for a Visa Electron.
island
30 Dec 2010
Well, the railways don't accept Visa Electron at all for the most part.
I used to work at a major retail bank and our internal procedure guides said that Visa Electron cards could not be phone-authorized. If that's wrong, then it's wrong.
GadgetMan
9 Jan 2012
Which is why I put the above.
wintonian
15 Jan 2010
Hampshire
Sounds like it.
They’ll just do what Easyjet have done and charge you an admin fee regardless of what debit card you use.
island
30 Dec 2010
Page 4 of this also agrees with me.
Zoe
22 Aug 2008
You said if the card is not marked electronic use only then you can phone for authorization. I was asking if it was not possible to do this with a card marked electronic use only as I don't see why this should not be allowed.
GadgetMan
9 Jan 2012
Sorry, misunderstood your post.
No idea as to the technical reason. It's company policy not to accept these cards onboard our trains.
headshot119
31 Dec 2010
Dubai
The Visa Electron card works like any other Visa card. Procedures at the point-ofsale
(POS) do not change with one exception. The Visa Electron card must always be
authorized through a POS terminal.
That does not exclude the use of phone authorisation. Most POST terminals allow you to manually enter the authorisation code you obtain over the phone.
lyesbkz
1 Dec 2010
Chesterfield
I understand that 'Electronic Use Only' simply means that since the digits aren't raised, the card cannot be used in one of the old-fashioned card imprinters. As far as I'm aware it doesn't affect any authorisation methods and a telephone authorisation should still be possible.
Feel free to correct me if experienced!
For what it's worth, the MasterCard website tells merchants not to process unembossed 'ELECTRONIC USE ONLY' cards in any way other than through the electronic POS terminal.
island
30 Dec 2010
It does to me. "Must be authorized through a POS terminal" to me implies "must not be authorized by a method other than a POS terminal, such as over the phone".
headshot119
31 Dec 2010
Dubai
But by swiping the card in the POS terminal and then manually entering the authorisation number you are running it through the POS terminal.
island
30 Dec 2010
Running: yes. Authorizing: no.
I think we'll have to agree to disagree on this one.
headshot119
31 Dec 2010
Dubai
Has the card been swiped through the POS : Yes
Do you have proof the card was present : Yes
Has BMS given you authorisation for the card : Yes
Have you manually inputted the authorisation number into the POS : Yes
What's the issue?
island
30 Dec 2010
What's the issue?
Have you authorized the card through the POS machine? This is not a separable statement.
island
30 Dec 2010
Yes by swiping the card and manually entering the authorisation number.
Can't say I agree that "manually entering an authorization number" is equivalent to "authorizing". You've "authorized" it over the phone and "processed" it through the POS.
headshot119
31 Dec 2010
Dubai
So by this logic then the instant you become suspicious of someone with a Visa Electron card, and you ring in Code 10, they still can't purchase. As when BMS give you the authorisation number you can't do anything with it.
island
30 Dec 2010
Good question. I expect the Code 10 call would either give you a "pick up card" or "proceed" but no authorization response.
Robbies
20 Sep 2009
Berkshire
Unless electronic authorisation demands a "Call for authorisation".
If by Visa Electron cards, you mean Visa debit cards then mine which I have had for the last three years nearly must be unique as it has been accepted both by voice and also by any Train Ticket websites.
Zoe
22 Aug 2008
No, Visa Electron is not the same card as Visa Debit.
dave87016
9 Dec 2008
Lancashire
I have a HSBC Visa Debit, I use it at shops, and to purchase tickets online and onboard trains, usually my card works fine, sometimes I board on the first train ( ticket office shut and machine Out Of Order) so when purchasing onboard a train sometimes it works sometimes it doesnt and when it doesnt I go to the ticket office where I alight and it works fine
Robbies
20 Sep 2009
Berkshire
Okay, I thought it might be different. Like dave87010, my card is from HSBC and has only failed me when I have put in the pin number incorrectly for it more than once.
