PHILIPE
Network Rail have imposed a last minute Possession resulting in bustitution between Abergavenny and Hereford from approx 1930 onwards to carry out urgent track repairs.
So the work isn't urgent enough that it can wait until 1930 tomorrow evening, but it is urgent enough it can't wait until midnight or the early hours of Sunday. Interesting.
Network Rail have now announced on the NRE Website that the work is from 2000 Saturday to 1600 Sunday in order to clear new TFW Stock. This would be the Mark IVs to hazard a guess
Cancellations to services between Abergavenny and Hereford
Due to urgent repairs to the track between Abergavenny and Hereford all lines will be blocked.
Impact
Train services running through these stations may be cancelled or delayed. Disruption is expected until 02:00 03/02.
Customer Advice
On Saturday 01 February 2020, due to essential work required to introduce newer trains onto our network , rail replacement bus services will run between Abergavenny and Hereford from 20:00.
Internal Information
Emergency T3 possession imposed on the Up and Down Main lines between 20:00 Saturday 01 and 16:00 Sunday 02 February.
Later trains will terminate and restart from Hereford and Abergavenny respectively. Buses will be sourced to cover the gap. Some additional trains will be restarted.
Further Information
Trafnidiaeth Cymru/Transport for Wales
If you have experienced a delay or cancellation, please contact our customer relations team or pick up a form from your nearest ticket office. You can email us using: [email protected]
Last Updated:31/01/2020 14:53
Although Journeycheck currently says
In order for Transport for Wales to introduce new trains to their network, emergency engineering work is required between Abergavenny and Hereford. Consequently, from 20:00 on Saturday 1 until 16:00 on Sunday 2 February, buses will replace trains between these stations to allow this work to take place.
Train services at Abergavenny and Hereford will also be retimed to help customers maintain connections with the bus services
It must be the MkIVs, but I'm not sure about the exact nature of the work. There'll be trains arriving and departing both stations, meeting the rail replacement buses, so at least some of the platforms will still be in use.Just seen this on National Rail Enquiries - is it to adjust platforms for the MK4s presumably?
http://m.nationalrail.co.uk/pj/disruption/details/151AE8CC208C42F6AF3D14A254D6BE39
Perhaps they're working on Pontrilas tunnel instead?
I don't quite follow. If platform 3 at Hereford were closed for engineering work, isn't platform 2 bi-directional (and could be used for both up and down trains)?If it is platform related it could only be platform 3 at Hereford. To turn back a train in service at Abergavenny you need to use both platforms, and at least one platform out of 1 and 2 at Hereford needs to be open to turn back trains from the North - and that being the case they could run them through to the South as well so that wouldn't explain the block.
(Also, are both platforms at Abergavenny needed to turn back a passenger service from the Cardiff direction? I.e. the crossover south of the station isn't cleared for passenger trains, and/or no suitable signal at the southern end of platform 1? I can see that the pointwork clearly doesn't allow turning back a train from the North without using both platforms.)
Work to introduce new trains is not "emergency engineering work" in my opinion (unless they plan to introduce them on Monday!)
Many thanks for the clarification.Platforms 1 and 2 aren't fully bidirectional. You can arrive and depart from the North into those platforms, but there isn't a signalled move for passenger trains from the south to go straight in. In that direction if a train is in service it can only use platform 3.
You are correct about Abergavenny - the signalling does not permit passenger trains over the crossover, so a shunt between platforms would be required to turn back there.
