Prudhoe
Unidentified 222 noted leaving Derby 16:42 1K21 D-C, then should work:
1K24 18:07 Crewe-Derby
1K27 19:43 Derby-Crewe
5K27 21:06 Crewe-Crewe CS
Especially in First Class.Wow that's some upgrade!
- Facilities on the 16:42 Derby to Crewe due 18:04.
Will be formed of 5 coaches instead of 2.
Calling at stations
It will only do the 1642 and 1807. 222's should not end at Crewe overnight.Unidentified 222 noted leaving Derby 16:42 1K21 D-C, then should work:
Very true. Last winter I got a 4 car 222 twice on the North Staff's. A 5 car though is more rare as its normally the 'hot spare' 4 car which ends up taking over the 15x.It is not completely unknown and has happened in the past especially o9n Uttoxeter Race Days
EMR really need to be more careful in that case as they cannot legally operate class 153s on that route unless they are coupled to a unit that is compliant with PRM legislation.Most likely short of units again. There's been a pair of 153's on Skegness services today again. They normally only venture there as strengthening with other units, or as a last resort to maintain the service.
EMR really need to be more careful as they cannot legally operate class 153s on that route unless they are coupled to a unit that is compliant with PRM legislation.
The ability to use 153s on this (and other) route(s) without being coupled to other units is meant to be in an emergency following a break down in service, and not as an excuse for EMR controllers to take the lazy option when diagramming. Considering that it is clear that the situation was caused by an ongoing shortage of available units and not unexpected problems on the day it really doesn't fall into that category, especially considering that EMR were using compliant units on diagrams that do not require them at the same time.Yes, they can, provided there are no alternatives to avoid a cancellation. They have to inform the Department for Transport of all such occurrences and action may be taken against them for it but ultimately if required they can do it.
Allowed to operate 153s as a last resort to avoid the service being cancelled.EMR really need to be more careful in that case as they cannot legally operate class 153s on that route unless they are coupled to a unit that is compliant with PRM legislation.
