EMR broke down at Luton: Air suspension failure?
Aictos
28 Apr 2009
Hearing reports that the air suspension on 1B36 11:12 Nottingham to London has failed and has now terminated.
What could cause the air suspension to fail?
Llama
29 Apr 2014
Burst air bag, air leak on pipework of any part of the suspension system, valves failing, could be many different things.
Aictos
28 Apr 2009
Not to mention the train will be rattling like no tomorrow?
Raul_Duke
29 Mar 2014
20mph out of service in a meridian with failed air suspension as well iirc. Ouch.
Llama
29 Apr 2014
Not really, there are secondary springs within most airbags, obviously I don't know what traction type it was. Deflated air suspension usually gives quite a lively ride and is often accompanied by a reduction in maximum permissible speed (say, on Sprinters max 45mph) especially if the affected vehicle is carrying passengers. If the affected vehicle is locked out of public use the max speed may be higher depending on traction. The actual instructions vary from TOC to TOC and for different traction. Most Sprinters etc are 45mph max with deflated suspension if in passenger service, up to permissible speed if affected vehicle locked out of use (Northern have an instruction for 156s which are still max 45 even if OOU, due to slightly different emergency springs apparently).
There are often a couple of other considerations for deflated air suspension at least on Sprinter type stock - brake cylinder pressures are high due to the load weighing system on the unit thinking it is fully loaded, and when coupling to other units.
Aictos
28 Apr 2009
I thought it was 40mph? Then again I’m not a driver nor do I use them/passed out on them.
tsr
15 Nov 2011
Between the parallel lines
Went at 40mph to Cricklewood. Fault was first identified north of Bedford by the TM and then it sat down for a bit at Luton. Caused a bit of congestion but nothing really awful.
hooverboy
12 Oct 2017
compressor fault?
that would surely affect brakes as well though?
hooverboy
12 Oct 2017
that does seem curious.
why the variance between TOC?
I would understand the remedial measures being traction specific.
Evacuation procedures may vary by TOC(ie on 158/159 with third rail present, but I'd expect someone passed on the traction to know it,irrespective of if they were running on that type of route or not)
CC 72100
23 Jan 2012
compressor fault?
Could be an air leak within the air suspension system. Isolating the air suspension from the Main Reservoir pipe would prevent further air loss on the vehicle but the downside would be insufficient air to operate the (already damaged) air suspension.
CC 72100
23 Jan 2012
Different TOCs have done different 'things' to their units in the +20 years since privatisation. Plenty of scope for different modifications and renewals that other fleets of the same class in a different part of the country may not have received.
Or just different because somebody different has decided it...!
hooverboy
12 Oct 2017
It would appear to be quite beneficial to have a few less of these "modifications".It would make training people to operate them far easier.
308165
11 Feb 2017
It may not be relevant here but there are also gauging restrictions on units with deflated air suspension. Either total bans from certain platforms or much reduced speed.
