EMT double Meridian services
Some while ago there was some discussion on here regarding which EMT services run as 2x222. I’m trying to put the up-to-date timetable into Simsig and am struggling to work out what the diagrams look like due to the amount of joining and detaching at St Pancras.
Would anyone be able to post a list of which up and down services are booked to be formed of 2x222, please? I’m interested in the normal MF timetable, not the amended one for the Derby resignalling.
Andy Pacer
11 Jul 2017
Leicestershire
I can only help with odd trips I’m afraid:
The morning ex Lincoln joins another set on arrival at Nottingham to run as a 4 + 5 set.
The 1007 through Leicester to Sheffield is a double 5 + 5 set
43055
8 Mar 2018
Most double sets run south in the morning and north in the evening. The following I know are double sets (10 car)
0723 Derby to London
1202 Derby to London (swaps with a 7 car on arrival at london)
1030ish Derby to Sheffield
Thanks both. These snippets have actually proved prettt helpful and I’ve managed to work out something which seems to work on paper, albeit there are a couple of errors in the working timetable with regard to platform numbers, so I’ve had to make a few assumptions.
As a supplementary question, can anyone say which services the 4-car versions operate on? One such is the Lincoln to St Pancras, but does the 4-car go on the London end or the Lincoln end after the hook-up at Nottingham?
Andy Pacer
11 Jul 2017
Leicestershire
I *think* the 4 car is on the back (Lincoln end) as the 5 car would be waiting in Nottingham to be coupled on arrival of the 4 car.
I did see a double set passing Syston southbound at around 0720 on Wednesday, but as you said initially there may be some quirks of the Derby Blockade Timetable.
louis97
14 May 2008
Derby
4 car goes onto the London end at Nottingham, 5 car comes in from Lincoln.
Crossover
4 Jun 2009
It may be a bit skewed with the Derby work at the moment - I saw a few doubles out a couple of Sundays ago (travelled on one too)
43055
8 Mar 2018
I think there is a few double sets on Sundays as there is only 2 services per hour for the most part of the day.
cactustwirly
10 Apr 2013
Correct, most of the 222 diagrams are double sets on Sundays, they also have all the HST sets out
