EMT timetabled wait near Hazel Grove each morning
Discussion in 'Allocations, Diagrams & Timetables' started by Haydn1971, 7 May 2015.
Thread Status:
  1. Haydn1971
    Haydn1971 Established Member
    2,050
    11 Dec 2012
    Sheffield
    Most mornings the EMT train I catch between Dore and Oxford Road is subjected to a short stop on exit from Disley Tunnel, sometimes it's as little as 30 seconds, other times it's several minutes... Is this a timing stage to avoid clogging the Greater Manchester stations up ? Annoyingly, the train stops just short of a mobile data signal ;)
    Rail Forums
  3. kjhskj75
    kjhskj75 Member
    125
    14 Jul 2012
    Presumably there is stuff going on at Hazel Grove and the signaller is busy with it, or perhaps a train is blocking a platform there. Check the timetables to see what else is happening there at that time.
  4. The Planner
    The Planner Established Member
    8,400
    3 minutes engineering time between Chinley and Hazel Grove, run on time you will get held or slow right down.
  5. yorkie
    yorkie Administrator Staff Member Administrator
    38,136
    This will either be:
    Both have 3 minutes engineering allowance and additionally 1 minute performance allowance shown at New Mills South Jn.
    The former appears to have been held to time (though it's unclear what it was held for) although it did lose about half a minute, but the latter was allowed to arrive into Hazel Grove early.
    So you were probably on 1R50, which is the 0627 from Dore.
  6. Haydn1971
    2,050
    11 Dec 2012
    Sheffield
    I was indeed on the former... Cheers for the feedback all
  7. 455driver
    455driver On Moderation
    11,332
    10 May 2010
    So its a 3 minute timetabled wait rather than a delay then!
    Another thread title which is presumptuous and wrong.
  8. yorkie
    38,136
    Fixed :)
    Edit: OP - as mentioned via PM, feel free to edit the original post with an appropriate title of your choosing.
  9. Tomnick
    Tomnick Established Member
    4,619
    10 Jun 2005
    Is the junction at Hazel Grove, or at least the line towards Buxton, inside the overlap of its protecting signal? With no sign of anything booked towards Chinley at that time, it seems unlikely that a train would deliberately be brought to a stand at the signal in rear of that one just to wait time for a minute or two!
  10. The Planner
    8,400
    Its not a timetabled wait either, its engineering recovery time, therefore logically you would expect a long dwell at Hazel Grove if nothing is wrong.
  11. Haydn1971
    2,050
    11 Dec 2012
    Sheffield
    On the evening train home, the guard announces a timetabled "halt" at Dore - no such announcement is made in the morning. As a passenger, it is natural to ask "why" something like this happens - to me as a passenger, it's a what appears to be an unnecessary delay in the middle of nowhere.
  12. MCR247
    MCR247 Established Member
    9,059
    7 Nov 2008
    Whilst as a passenger its reasonable to ask why, do you really think that it is likely to be an 'unnecessary delay' i.e. the signaller just feels like holding your train for no reason
  13. Haydn1971
    2,050
    11 Dec 2012
    Sheffield
    The OP was enquiring why out of curiosity. When something is unknown, it appears unnecessary until it's explained - whilst the halt is regular, I often see other passengers looking around wondering what's happened - perhaps it's because we have become accustomed to other random halts as a result of signal faults, trespass, cable theft etc - regardless, it adds a small degree of travel anxiety.
  14. crehld
    crehld Established Member Senior Fares Advisor
    1,982
    1 Nov 2014
    Between Crewe & Hellifield
    I'd agree with this. And perhaps a little communication from on board staff would be an easy way stop this speculation/curiosity/anxiety which seems to upset some people. Indeed, it could even work in a train company's favour by highlighting the fact the service is so incredibly good and reliable that you've arrived early! ;)
    A while back I used to commute between Portsmouth and Petersfield. Every evening we were held outside Havant for three or four minutes, but it was always explained that we had arrived early, we weren't due into Havant for a few minutes yet and that we were still due to arrive into Portsmouth on time without delay. This sort of simple but proactive approach puts people's minds at rest, especially those who might not have an in depth understanding of the role of engineering allowances, timetabled waits and so on (i.e. the vast majority of us whinging passengers).
  15. johnnychips
    johnnychips Established Member
    1,614
    19 Nov 2011
    Doncaster
    Whenever the South TPE is held outside Manchester Airport, the guard usually explains that we are early and waiting for a train to leave the platform.
  16. The Planner
    8,400
    Looks like just one of those things where the timetable falls that way. You get to Dore at the same time as a St Pancras - Sheffield EMT. The EMT passes Dore Station Junction at xx.36, you can't go until xx.38 because of that, but the Reading Newcastle XC passes Dore Station Jn at xx.40 so that doesn't work. Therefore you get stuffed until that passes which makes it xx.42 until you depart. In reality its probably slightly earlier as the driver will go on the single yellow and not the green we time to.
  17. edwin_m
    edwin_m Veteran Member
    13,063
    Presuming this is the 1743 from Piccadilly, I think this is a consequence of the extra stops at Chinley and Dore knocking this train off-pattern so it can't get ahead of the other trains as it does in other hours of the day. I don't think this happened before the EMT acceleration of London trains, before which the slower train to Sheffield waited several minutes for a path at Derby so would have passed Dore quite a bit later.
    Regarding the eastbound train in the OP, EMT towards Liverpool has to get through flat junctions at Hazel Grove, Edgeley No1 and No2 and Slade Lane before it gets to Piccadilly. All have other train services on conflicting routes so if it misses its slot it will delay itself further or delay something else. The line from Sheffield to Hazel Grove is probably more prone to delays than most because of the long signalling blocks and the risk of poor weather conditions in the Peaks. So it is wise to allow some "recovery time" before the first of these junctions. Probably if there was a clear route through to Hazel Grove the signaller would let it continue. If stopping there it would then take the extra time as a longer stop, otherwise it would probably end up standing the signal protecting Edgeley No1 (certainly a frequent occurrence at other times of day).
  18. The Planner
    8,400
    Its not recovery though, its box time (although excessive, 3 is a lot for one location). If it was 3 in a diamond then I would agree.
  19. LowLevel
    LowLevel Established Member
    2,765
    26 Oct 2013
    We can only announce something we know about. Engineering and patching allowances aren't on our job cards. As far as the guard is concerned you're just stopped at a signal and the 2 minute then 10 minute announcement procedure applies.
  20. 455driver
    11,332
    10 May 2010
    Thats why I never took power after leaving Buriton tunnel, I just let the gradient do the work and it loses a few of those minutes as well so the train might not have to even stop before Havant Jn. This assumes the train was on time other wise its power up and use those minutes to pull a bit of time back.
  21. oddiesjack
    oddiesjack Member
    235
    11 Jan 2012
    High Peak
    Last year, I used to use 1R50 (The EMT service the OP was asking about) daily, and regularly was held at the signal protecting Hazel Grove High Level Junction, which IIRC is HG21.
    This was invariably due to 2H90, the 06:49 Manchester Piccadilly-Buxton service being 2 or 3 minutes late leaving Hazel Grove. On leaving Chinley, I would check on how this train was running (on RTT), to see if my train would be held at Hazel Grove High Level.
    In general, if it was on time, there would only be the briefest of delays, or none at all.
    If it was 1-5 minutes late, there would be a commensurate wait.
    If it was over 5 minutes, the HGR signalman would normally allow us out over the junctions before the Buxton train left the station, so again, no delay.
    I also think the section from the Up station starter towards Buxton is fairly long, and is certainly an adverse gradient, so it takes a good couple of minutes for an Up train to clear
    There is a signal protecting the Low Level Junction, but this is on the single-line chord section, and possibly the rear of the train may still be fouling the High Level Junction if held here, both good reasons why trains will be held at the preceding signal.
Thread Status:
Share This Page
