T
Tom
Guest
3495 (finished today) will work 09.36 AD - CS (approx 15 - 20 l/s),
then 11.14 CS - AD, 12.57 AD - CX, 14.30 CX - AD then finished.
3579 finished tonight will be on 17.22 CS - AD.
3445 due to finish next Friday will NOW form 17.26 TN - TW, 17+42 TW -
TN, 17+55 TN - CS, 19.07 CS - TW, 20.10 TW - TN.
3548 due to finish next Friday will form 11.18 VA - CU, 13.24 CU -
VA, 15.41 VA - FV, 17.14 FV - VA, 20.48 VA - AD.
3416 due to finish next Friday will form 09.45 DP - MI, 10.20 MI -
DP, 11.15 DP - RM, 12.00 RM - DP, 12.45 DP - MI, 13.39 MI - DP, 14.15
DP - RM, 14.58 RM - DP, 15.49 DP - MI, 16.41 MI - DP, 17.40 DP - MI,
18.28 MI - DP, 19.20 DP - RM.
From Monday owing to the continued shortage of stock the 17+26 AD -
CS will come up early every day to form 17.26 TN - TW, then 17+42 TW -
CS, and the 3 x 375 that would go to TW and back will form 17+31 TN -
RH, 18.07 RH - TN. The usual CM&EE move the mountain to Mohammed
approach, rather than actually put some pressure on the depots to
produce the booked amount of stock.
Still doesn't explain where all the VEPs to cover Networkers are
coming from when they can't seem to stop hitching units up and towing
them away. Two weeks off, and the fleets attitude to planning still
resembles the "monkeys and typewriters" approach to novel writing.
Colin
Colin
