End of Yellow Front Ends?
XCTurbostar
13 Sep 2014
Firstly, apologies for digging up a dead thread.
However, I have been in contact with the RSSB regarding the 'yellow ends' discussion.
See below correspondence from the RSSB
The Framework within which GB standards apply is largely as a result of European law. RSSB has published a Strategy for Standards to define the role of Railway Group Standards in the future. The aim is to shrink the pool of Group Standards and to migrate to the use of TSIs and Euronorms (European standards).
In the new framework there is still a role for a selected number of Railway Group Standards to fulfil the following functions:
- To close an ‘open point’ in the TSI. This is where the various member states couldn’t agree on a solution for a particular issue, so the states default to their national rules.
- To address a country ‘specific case’ in the TSI. The GB loading gauge is a good example of a specific case – it’s smaller than in mainland Europe so we have to use national rules to manage it.
- Finally, for compatibility with ‘legacy’ infrastructure. You may be introducing a new train, but it still may need to operate on some 150-year old infrastructure, so some additional national rules may be needed to manage this.
Unfortunately, GMRT2131 didn’t tick any of the above boxes. The only way GB can mandate yellow front ends would be for us to lobby our European colleagues to mandate them also, by changing the TSI or its associated Euronorms.
Now this might open a can of worms here but I'd like to see what you all think.
Thanks,
Harbornite
7 May 2016
It would be interesting to see what the stats are for railway workers who have been killed by trains in continental Europe, and see whether or not there is a correlation with yellow panels. This makes you wonder how people manage in France, Germany, Poland and elsewhere where yellow panels aren't used.
Phil.
10 Oct 2015
Penzance
It also makes one wonder how LUL seem to manage on the surface without yellow ends. Yellow ends are like Guards. They were fine in their time but modern methods have overtaken their original purpose.
Please don't start banging on about Absolute Block. I've stated modern methods not dinosaur methods.
notlob.divad
19 Jan 2016
That is interesting, as a person who is fully behind standards and the idea of standardizing, I think this is excellent.
I've read somewhere, probably somewhere up thread that it is linked to the modern standard of headlights. If the modern standard is deemed to be bright enough and reliable enough to be acceptable without yellow fronts, is a dark color better. Rely on the lights for nighttime / dark conditions, but a dark front end to differentiate on a sunny day and give the lights something to contrast against.
It also makes one wonder how LUL seem to manage on the surface without yellow ends. [/I]
I think a significant difference is that, at least on their own routes, LU do not normally have people working on the tracks during running hours. That isn't to say it never happens at all, but it isn't done in quite the same way as NR infrastructure.
LU have red ends, which are almost as visible. SBB and DB both use red ends on much of their stock (though not all).
Dstock7080
17 Feb 2010
West London
Non-automatic Lines certainly do, today i've had vegetation control - in 3 separate places; signal engineers - repairing Piccadilly Line problems; track team taking possession in Barking sidings; routine track patrol guys, both east and west.
Trog
30 Oct 2009
In Retirement.
Yellow paint costs nothing as the front of a train would have to be painted some colour, so even if it is only slightly useful every now and again it should be retained. My personal experience is that in a heavy heat shimmer, a yellow front shows up more than the lights, as the distortion of the image alters the size of the yellow patch. The same effect tends to scatter the beam from the lights reducing its visibility, so in an ideal world I would want a nice bright light on a yellow and black end. Surely that is not too much to ask if the railway industry is really serious about staff safety.
cadoxton
24 Dec 2014
Why ?
Staff are still protected and it comes with a caveat that headlights meet a higher standard.
TOWS
Lookouts
Possessions
Blue fencing <--
restricted speeds
Late notice case
Not not forgetting the high vis clothing or the Driver's requirement to blow up when sighting people within the boundary fence.
What is the rule regarding blue fencing?
380101
18 Feb 2015
most work sites now have temporary fencing erected to keep track workers the right side of a running line. Speaking with a NR supervisor last week as had him in cab to check the line and he said they (NR) do not do any work on running lines now. seems it's only contractors like QTS etc that still work lineside when the lines are open.
cadoxton
24 Dec 2014
Thanks for clarifying.
I did wonder why such a non-striking colour was used for this.
zn1
3 Sep 2011
it doesnt matter even if lines are closed - men and women are working close to open running lines...regardless of how much barrier is between them..there will always someone who strays...if a yellow end saves one person a year from death then its worth keeping...you may not hear a train coming but a good lookout will see it before he/she hears it - thats why the yellow end is important!!
Harbornite
7 May 2016
Surely the yellow isn't necessary because of the high intensity headlights that modern trains have?
Clip
28 Jun 2010
Even if the lookout sees a train later than they should they should still be positioned in a place so that enough warning can be given to the work party to move to a position of safety.
alxndr
3 Apr 2015
Depends on the work, or perhaps is a regional thing, in my experience red zone often still takes place where safe to do so and line blockages aren't an option for whatever reason. If working near, but not on, a running line a Site Warden will be appointed to ensure no one strays. Only time I've ever encountered blue fencing is when it's already there, usually seemingly placed by contractors doing jobs over several days.
trash80
18 Aug 2015
Birches Green
I dunno a few times i've seen the yellow end of approaching trains (modern stock, 172s and the like) before the lights (viewed from the platform not rail side i should add). The yellow always works too even if its pretty dirty while lights of course can always fail...
Harbornite
7 May 2016
Quite right you can always employ replacement P-Way staff, it is not as if we are particularly clever or skilled. :roll:
That's a very mature response to my comment, not OTT at all. I wasn't aware of p way staff being killed in their droves in Germany or France so why should things be different here. If there is concrete evidence of a correlation between deaths and yellow panels then I'll retract my statement.
Marklund
18 Nov 2010
Have you seen a post from anyone who works on the line who is saying, yes, get rid of them?
Harbornite
7 May 2016
No, but I've yet to see evidence that getting rid of the yellow will lead to an increase in track deaths. If this was to occur then I'd support the idea of reintroducing them.
Harbornite
7 May 2016
Thanks, that says it all.
Not really. I'm not surprised that staff prefer having yellow panels because that is what they are used to working with. It's worth seeing what happens without yellow panels before judgment is passed.
Marklund
18 Nov 2010
You've been told headlights aren't the answer already though.
And yes, I've seen enough of the newer stock with higher intensity headlights to form my opinion from working trackside.
What's your first hand experience?
Harbornite
7 May 2016
I don't work in the p-way department so I don't have experience from track level. I can say that in quite a few cases where I've been waiting alongside straight stretches of track, I've seen the headlights before the yellow panel, and this was particularly apparent with the Network Rail Loram grinder that I saw at Tamworth on one occasion. One of the only times I recall seeing the panel before the headlights was at Dunster, but that was a heritage DMU with poor headlights. As I've said, I'm not sure how they cope in France, where safety panels are nonexistant, or in Germany where rolling stock only has small white panels.
Fred Dinenage
23 Jul 2013
Really? You're advocating a potential increase in risk to track workers for some aesthetic reason? Do you think you know better than those who actually work in the rail industry?
