Engine rpms in DMUS
Discussion in 'Traction & Rolling Stock' started by notadriver, 21 Jul 2019.
  1. notadriver
    notadriver Established Member
    3,214
    1 Oct 2010
    Does anyone know what the engine rpms were at top speed in the following units.
    First gen DMU with 4 speed transmission (70 mph)
    Class 150 / 156 sprinter / super sprinter.
    (75 mph)
    Class 158 (90 mph)
    Class 168/170 (100 mph)
    Class 185 (100 mph)
    Class 180 (125 mph)
    Many thanks.
    Rail Forums
  3. driver9000
    driver9000 Established Member
    3,653
    13 Jan 2008
    As I remember 14x and 15x units are 2,100rpm.
  4. hexagon789
    hexagon789 Established Member
    5,758
    2 Sep 2016
    First Gen mechanical DMU - 1,800rpm for those with the 150hp engines, not sure about the other engine types.
    15x Sprinters are 2,100rpm
    158 are 2,100 with the Cummins and Perkins 350hp engines but 1,900rpm with the Cummins 400hp ones.
    168/170 are 1,900rpm
    185 and 180 are both 2,100rpm
  5. notadriver
    3,214
    1 Oct 2010
    Thanks to you both. I’m wondering if when the transmission goes into ‘direct drive’ or the last gear whether the full rpms is needed at max service speed?
  6. hexagon789
    5,758
    2 Sep 2016
    Yes, at full revs the train should be at max speed more-or-less. In a first-gen DMU, at 1,800rpm in 4th gear train speed will be approximately 65.5mph.
  7. 37057
    37057 Member
    146
    3 Jul 2009
    I've had a 185 engine at 2100 RPM but that was sat in the depot with a laptop plugged into the CCU.
    I've found an entry for a 185 doing 100 MPH with the Power-Brake Controller in 100% (CCU drive at 100% also) and 51 car at 1996 RPM, 53 car at 1983 RPM and 54 car at 1916 RPM. I would guess and say that wheel diameter is a major variant in these figures, however this is only a snapshot and these figures can vary by the second.
    There is also an entry logged for overspeed too at 102.6 MPH with 2033 RPM being the highest before being shut off automatically.
    A quick search of recent overspeeds across the fleet shows the highest being 2087 RPM, so it appears 100 MPH and below, these units don't actually hit the quoted figure.
    These transmission's "direct drive" are fluid couplings on 2nd and 3rd stages.
  8. hexagon789
    5,758
    2 Sep 2016
    I know it will vary unit to unit, but for 185s 2100 was the figure I had for them.
    Presumably then 2100 is the absolute maximum the engines will run at but to attain the rated 100 mph doesn't require the maximum engine speed giving a certain amount of leeway as it were.
  9. ash39
    ash39 Established Member
    1,282
    8 Feb 2012
    2100rpm will most likely be where the fuel cut off kicks in.
    If it's anything like an automotive engine, max power is usually achieved just short of max rpm.
  10. 37057
    37057 Member
    146
    3 Jul 2009
    2450 RPM is the limit for the QSK19 and that's when the 'Fuel Shut Off Valve' would de-energise, there would have to be something dangerously wrong if it were to reach this speed.
  11. ash39
    1,282
    8 Feb 2012
    I imagine the sound would be pretty spectacular!
  12. Ben Bow
    Ben Bow Member
    206
    20 Sep 2018
    Short video on Youtube showing a bench test on a QSK19 (180/185/Voyager/Meridian), quite interesting:
  13. hexagon789
    5,758
    2 Sep 2016
    Driver trying to emulate an HST? ;):lol:
  14. hooverboy
    hooverboy Member
    680
    12 Oct 2017
    for sprinters I think the torque convertor shifts at about 40mph.
  15. hooverboy
    hooverboy Member
    680
    12 Oct 2017
    as with most engines, maximum efficiency is between 60-70% of full rpm.
  16. hexagon789
    5,758
    2 Sep 2016
    Varies depending on a number of factors, but under full power the change to the fluid coupling is typically at 45mph in 75mph Sprinters.
  17. superkev
    superkev Established Member
    1,444
    1 Mar 2015
    west yorkshire
    Slightly off topic but there seems to be a few 185 experts here but my question is:-
    Has the hydro(something) retarder built into the 3 speed 185 Voith transmission been disabled. I seem to remember it had some initial problems?
    Thanks
    K
  18. 37057
    37057 Member
    146
    3 Jul 2009
    They're all working providing the engine is running. Occasionally they may get isolated temporarily to combat overheating in the summer but that's rare.
  19. hexagon789
    5,758
    2 Sep 2016
    They are in use, though occasionally don't know how long after the initial issues it took for them to be sorted to be more reliable level. If you look up Don Coffey on YouTube you'll find a number of 185 driver's eye views and you can hear the retarders in a couple of them.
  20. superkev
    1,444
    1 Mar 2015
    west yorkshire
    Thanks to all
    K
  21. notadriver
    3,214
    1 Oct 2010
    Thanks for all your great replies.
  22. Llama
    Llama Member
    843
    29 Apr 2014
    Correct, anything changing up from torque converter to fluid coupling at 40mph or below with full traction power applied and I book it as a fault.
    158s (all engines) change up to fluid coupling at about 55mph under full power.
  23. hexagon789
    5,758
    2 Sep 2016
    Though can't Sprinters change-up under 40 in lower power settings?
  24. Llama
    Llama Member
    843
    29 Apr 2014
    Yes, about 30mph in 150-156 units in power notches 1-3, then incrementally 3-4 mph higher through the notches up to ~45mph in notch 7.
  25. hexagon789
    5,758
    2 Sep 2016
    Thank you, I thought I'd read that was the case somewhere.
  26. superkev
    1,444
    1 Mar 2015
    west yorkshire
    Thinking about my earlier post re the 185 retarders dont the less reliable 180s have the same engine and power train.
    K
  27. hexagon789
    5,758
    2 Sep 2016
    Yes, same engines and same basic transmission but set up for 125mph so presumably different change-up speeds etc
  28. superkev
    1,444
    1 Mar 2015
    west yorkshire
    Thanks. I wonder why the 180s particularly the Hull trains ones seem to feature so much in failure reports.
    K
  29. hwl
    hwl Established Member
    3,783
    5 Feb 2012
    Different final drive gearbox ratios
  30. 37057
    37057 Member
    146
    3 Jul 2009
    I've said this before in another thread and clearly got ignored!
  31. hwl
    3,783
    5 Feb 2012
    I know the feeling!:rolleyes:
Share This Page
