Looking down the specifications of the English Electric Type 1 (Class 20) and Type 2 (Class 23), it seems to me that the two are practically identical in terms of traction characteristics, with about the only difference being the addition of a steam heat boiler on the Type 2. Meanwhile, the Type 1 is considerably more powerful than its' competitors from other manufacturers. To me, this suggests that the choice of prime movers was a little adrift.
With a 6-cylinder engine - the 6SRKT fitted to several export locomotives - the Type 1 would have had 750hp on board for a little under 600hp at the rail, equivalent to the BTH and NBL competitors and presumably lighter and cheaper to run as a result.
Putting the 8SVT into the Type 2 would probably have meant a slightly heavier design than the Baby Deltic, though perhaps not too much so given the extra structure put in to offset the lightweight prime mover. Traction characteristics would be more or less unchanged, and you'd wind up with a locomotive of more conventional design and presumably higher reliability.
This seems like a more sensible course of action, at least from English Electric's point of view.
I can see the point of trying the Deltic out in a mixed traffic locomotive, which partially justifies the choice as an experiment. The grossly overpowered Type 1 prototype, which was basically a Type 2 powertrain dressed like a trip freight locomotive, I find harder to explain. Does anyone know what the logic was?
