With Aluminium repairs you would are looking at AC TIG welding rather than the more common DC TIG Welding. The AC TIG equipment is 5x more expensive and really doesn't agree with electrical equipment, hence Roger's comments.
Given the depth of the cracks welding could just be described as the equivalent of not much more than papering over the cracks and would be a temporary fix.
It would just be buying time till a bigger fix unless they were caught early.If they are anything like the Yaw Damper Cracks, I wouldn’t want to be just papering over those cracks. The ultrasonic NDT testing revealed cracks up to 15mm, which for a pretty new train, is not a good figure to have.
And no through trains to Exeter on South Western all weekend because of planned engineering work in Salisbury area. Perhaps Network Rail should cancel tomorrow's work to give some folk at least an alternative.GWR cancelled all long distance trains today - and saying no replacement transport. What about people who are away from home for business or other reason and need to return home? Different situation to people starting out.
Back, sack, or the jack cracks?Cracks in the jacking points it seems.
Not according to their web site.i notice TPE 802 between newcastle and liverpool are running as normal? am i missing something?
Whilst I think many people are doing their absolute best at keeping as many people as they can moving it’s a real shame that we have already got reports of ....
*refunds being refused because the train was reinstated and people were told not to travel
*tickets being rejected on alternative operators services despite it being an official alternative.
*lots of people being charged admin fees.
*passengers being told to use delay repay when they don’t travel (cracking fraud case coming up in September 2022, I look forward to the thread)
* passengers told that they must have a new seat reservation or they can’t travel, then the actual trains that run being a free for all
*passengers thrown off at random stations due to overcrowding
* people made to surrender their advance singles and buy SVRs for a service 2 hours later. Then having their refund on their original train rejected.
It’s a real shame that these sorts of issues (which are nearly all resolved with a fight) do seem to crop up every single time there is disruption anywhere.
little wonder passengers get angry.
No, they were operated as fixed formation sets - while it may have been possible to knock out a defective coach a wholesale reformation of HST or and other stock simply wouldn't have happened. Any idea that something else would have happened is just looking back with rose-tinted glasses.If there are plenty of unaffected carriages, in a similar situlation HSTs would have presumably offered a bit more flexibility in putting together useable rakes from what was available. (And loco hauled rolling stock perhaps even more so).
yeah i edited my postNot according to their web site.
Random cancellations - alternative ticket acceptance in place.
But that is at least better then their earlier "do not travel" advice.
Maybe they are covering with at least some 185s.
Is the safety issue an actual structural concern, or is it more that pieces might fly off at high speed? The speed of the inspections might suggest the latter?
However, passenger numbers are picking up and will continue to do so over the next few weeks so timing rather unfortunate in that respect.Blimey! Just catching up.with this one. Glad this is happening at a time where rail demand remains low.
I would say very much safety critical if you want something to connect the bogies / suspension on to!
Not in the middle of a major junction rebuild.And no through trains to Exeter on South Western all weekend because of planned engineering work in Salisbury area. Perhaps Network Rail should cancel tomorrow's work to give some folk at least an alternative.
Hmmm.
I always assumed that the mixed livery rakes that have appeared during livery changes were due to coaches being swapped between sets.
That’s because an 800 was found to have “severe” cracks on the welding on “multiple” jacking points (i.e. what’s used to lift the tra at Stoke Gifford last night.Sorry if I have missed it in 15 pages, but what changed overnight, as yesterday they were ok to run, today only ok after inspection
Its not like cracks only form between midnight and 4am, so there has to have been a event that led to issuing an urgent stop and inspect instruction.
Just because you have enough trains, in theory, doesn't mean that you can simply substitute one train for another. You need crew that sign it, the ability to match the performance of the substituted unit, and if it goes on for more than a few hours, stabling facilities in the right place where you can keep them.They've got enough 185s to run near enough the whole service (well, the pre-80x service) provided they're all single ones, as that's what they actually did with it for a period of time pre-350. OK, they had the 170s then, but they've got the 397s now.
I'd forgotten that the Newcastle TPE trains are 802s. In my mind they are still 185s.given the problem is affecting both LNER and TPE as well as GWR and HT, this is an industry wide problem.
LNER and TPE are reunnong buses between newcastle and York, some TPE services are in the hands of 185s and mutual ticket acceptance is in place. XC have stated only flexible tickets are being accepted as capacity is limited. There is only so much that can be done until each unit is examined and accepted back in to traffic. I cant see this returning to normal until Monday given the size of the fleets involved
Just because you have enough trains, in theory, doesn't mean that you can simply substitute one train for another. You need crew that sign it, as well as stabling facilities where you can keep them.
LNER are the only operator Grantham-Newark-Doncaster too. A slow detour via Lincoln is possible but very low capacity.Most journeys on East Coast can be covered not using their services. The worst bit will be between Newcastle and Edinburgh.
Great Westen is worse with 'network holes' between Didcot and Bristol Parkway / Bath Spa / Gloucester, between Oxford and Worcester and between Newbury and Taunton.
I'd not be too worried about Newcastle- Edinburgh.Most journeys on East Coast can be covered not using their services. The worst bit will be between Newcastle and Edinburgh.
They don't anymore, unfortunately.In my understanding all TPE crews sign 185s. Getting and keeping them in the right place may be a challenge, though, as you say.
Just like people give up driving after the first time a road is closed by a crash. That is to say it does not happen.and decide "never again" and drive next time.
