notadriver
- Joined
- 1 Oct 2010
- Messages
- 3,653
Does anyone have the 0-30/60 mph times for a Desiro on third rail? 60 seconds to 60 mph is the approximate figure for an Electrostar 375 which I think are like 377s.
I thought the first batch of 350s were built as 450s then given AC equipment - how can they be faster on DC when lugging a transformer ?
A marked contrast to Southern's recent order for 377s, thanks to the Thameslink rolling stock delays, which have to be built in a much shorter timescale.The only daft thing about the programme is how ridiculously fast it is - look at the Thameslink rolling stock programme as announced in 2008 (from RGI).
Thameslink rolling stock procurement timetable
Return of expressions of interest June 9 2008
Introduction complete December 2015
This was presumably after the DfT had produced the spec for the train!
That's a plus point for Derby-built stock over the Siemens trains then.the Siemens units are heavier than the Class 377s
Wrexham to Bisdon doesn't benifit from being able to make use of any other feeders (Unlike Kirkby to Wigan or Omskirk to Preston that can make use of the WCML power supplies) so it would purely be an installation opportunity thing, I get the feeling that DC would be better placed, as it is isolated.
But if Kirkby and Omskirk become through stations again and electrified, chances are it will be 25kV OHL from there to the WCML.
So yeah, if you can get a financial case and backing, with Merseytravel as a collateral for the debt, it could be a good way to go.
Some interesting points on Radio Merseyside today. They propose to purchase the new units, rather than hire them via one of the rolling stock companies. (They currently pay £12 million per year hire charges for the 507/508 units)...
Strap me in if there'll be one!
The only technical difference between the two classes is the coupler. Aside from that, different livery, interior job and operators, they are exactly the same. A lot of Southerns 377s started life as 375s.
So yes if that is the case for 375s, that will also be the case for the 377s.
'455driver' provided figures previously for 450/444, although of course these are the restricted figures. 350s are noticeably more spritely, even on 3rd rail.
Where could I find the figures please ?
It would be interesting to see whether a 350/450 or "mainline" electrostar would actually fit through the tunnels.....
(and in the case of the Desiros, whether they would go through without taking the track with them!)
Well 66s and Mk2s have definitely been through the tunnels. The last time this came up I think we debunked this myth - pretty much anything could fit down there.
Both 350s, 450s and 444s have the same traction motors, with the same power output, the main difference between the 350s on AC and 450s on DC are that the 450s are current limited for power draw, takes a lot of current to get the motor started, then when it's rolling uses less and less. So the 350s can draw a massive surge of current to get going where the 450s cannot.
Toilets would not just add weight, they would add the need for servicing facilities at depots...
And they would get completely vandalised by local youths. Toilets on the Merseyrail network would be a very bad idea in my opinion.
Not really necessary anyway considering most of the journeys are short and the major stations have free customer toilets.
But it might not be applicable to the Desiro City versus the Aventra- Siemens might have figutred out how to "add lightness" to their designs (borrowing from Colin Champman's design philosophy)
