The local trains running out of Lime St to Wigan, Manchester and Warrington all have toilets which seem to work whenever I try to use them. So why would the Merseyrail trains fare any worse?
Merseyrail is essentially a metro network. Having toilets on the trains would not make much more sense than on the London Underground. You may as well have First Class and a buffet car whilst you're at it.
My view on Mersey Rail getting new rolling stock is that the DfT go ahead should only be given upon condition that a large enough order is placed to ensure a rolling stock programme is given the green light to be able to ensure the eventual replacement of the PEP Class like for like and also to ensure future schemes like the Cardiff Valleys are catered for.
My reasoning being is that if Mersey Rail bosses consider the Classes 507s/508s to need replacing then surely the older Class 313s/314s ought to be replaced at the same time if not before?
Plus surely it would be more cost effective to do this then do multiple orders with large gaps between the orders.
Now while the successor to the Class 313 design needs to be 3 coaches due to the limits of the Northern City Line meaning they can only operate in 6 car formations, I do think the successor to the Class 314 design should be 4 coaches like the existing Class 315 design and able to run as 8 car formations which bearing in mind I'm not a regular user of the 314s in Scotland should bring extra seating capacity which in turn should help promote growth on these lines.
What Merseyrail need is metro-style stock that can accelerate and decelerate quickly, has wide doors & entrances for quick boarding & alighting, plenty of standing room and a light profile so it doesn't chew up the tracks, taking into account the tight curves and clearances in the underground sections. Fortunately, I think this is pretty much what Merseytravel are plumping for.
Not sure about metro-style stock, but I understand that Gareth is right in that Merseyrail want something that is lighter than the current stock, and that will cause a lot less track wear on the Liverpool loop.
Tram-like stock with fewer seats and lots of standing room would not be welcomed by the large numbers of passengers travelling all the way from Liverpool to Chester or Southport.
for example instead of wiring each component into the cabs at both ends of the train you instead have a networked approach where the components are networked IP devices sharing a common trunk data cable to the cab, next gen units will even dispense with the trunk cable and use a wi-fi like connection to connect all the devices in a carriage and then the carriages with each other.
if ERTMS is implemented entirely with GSM-R and doesn't have track-side Belizes as a backup.
Data Networking at low level is one of my (many) specialisms
and HSTEd; what about:
Door Controls? MU TBC Controls? Interlocking? TMS? etc...
Firstly, I would like to oppose the use of stereotypes here. There are scallies everywhere. Not just in Merseyside. And if a Scally lived in Warrington I am sure he would have little choice but to use Northern. To say that they choose only to "scally" around on Merseyrail trains is a bit silly - they don't have a lot of choice who their local TOC is. And its not up to Merseyrail to refuse any one for how they look for as long as they are fare-paying passengers.I've never seen the local scallies use Northern, or other TOC's that operate through Manchester/Warrington, a lot of the time when I'm using Merseyrail I see groups on them on the train causing trouble, being aggressive and abusive towards other passengers, and fare evading. All they seem to want to do is cause trouble.
No doubt in my mind that toilets would get graffiti'd all over constantly. The walls of most Merseyrail trains have been defaced; obnoxious remarks, and peoples names engraved with knives and keys.
Although toilets may be a nice addition to Merseyrail those travelling slightly longer journeys, i.e. if someone was travelling from Southport to Chester, or disabled passengers, I feel these people would ruin it for everyone else. I didn't come here to argue, by the way. Just stating my opinion. Just find it a shame that kids like to create an unpleasant and depressing atmosphere.
I'd need to check that, but I don't think there are that many channels in the TDM and when it was designed there was still a harness for door controls and interlocking. Either way, there's 100+ wires for a reason, and you can visualise a lot of them, but you'd still need at least 20.
To change tack for a moment, is there any real requirement to have the same stock on both the Southport and Birkenhead lines?
Would one type of train be more suited to one than the other?
Two types of train makes life more complicated & expensive. Two types of spares to keep, two types of train to learn traction knowledge or maintenance procedures, etc.
True, and I appreciate that there's very little difference between a 507 and a 508 at the moment - I was just asking a hypothetical question given that there was suggestion of something closer to a "tram" by some posters, yet the two lines (Northern and Wirral) may not require the same type of stock (i.e. do they both need to be three coach multiples?)
1. The platforms, especially in the underground parts, all accommodate 2 x 3 car units. Any alternative situation would cause problems - if there were 4 car units, they could only be strengthened by a 2 car train. If you just had 2 car units, you would have 6 driving cabs in a six car (3x2) formation, and that is more expensive than just 4 cabs in a 2x3 formatiom.True, and I appreciate that there's very little difference between a 507 and a 508 at the moment - I was just asking a hypothetical question given that there was suggestion of something closer to a "tram" by some posters, yet the two lines (Northern and Wirral) may not require the same type of stock (i.e. do they both need to be three coach multiples?)
2. Both the Northern & Wirral lines have some very-well loaded trains. Whilst most trains run a 3 car formations, a few peak hour services run as 2x3 car formations. Ideally, they could do with more 2x3 car formations, especially when there are special events in Liverpool, or on Chester race days.
