Where are you actually coming from?The national rail journey planner suggests going via Vauxhall and Victoria line, why not via London Bridge and Thameslink to St Pancras?
Which is faster/more efficient/easier? I have to get 10.24 Eurostar to Paris.
The clue is in the title: Epsom.Where are you actually coming from?
Having made the change at Vauxhall many times myself, I am wondering why you have such a downer on it? Certainly I would prefer it at rush-hour to fighting through the crowds at Waterloo, and then having to change yet again at Oxford Circus. Changing at Vauxhall allows you to get on the Victoria line before all the crowds at Victoria get on, and takes you straight through to St.P. As long as you are on a service that stops at Vauxhall, I would recommend it as an interchange.Having tried the recommended Vauxhall change previously - not in connection with Eurostar - I would say avoid that; it would be better to carry on to Waterloo then for Eurostar the Bakerloo Line to Oxford Circus then Victoria Line to King's Cross. ( NB The planner will also suggest Vauxhall for journeys that involve Euston, and in those instances it's definitely faster to go via Waterloo and the Northern Line! But that's for another thread... )
Each to his own, I suppose. I find Waterloo in the rush-hour an absolute nightmare. Likewise Oxford Circus.Because, having tried it, I find it slower and considerably more awkward than going via Waterloo. Vauxhall in the rush hour is extremely crowded and the stairways are very narrow. Off peak, Waterloo is not crowded so that issue doesn't arise in the first place. In the peak, there is an officially delineated clear space on the concourse at Waterloo* for walking the width of the station which most passengers do seem to observe.
The Oxford Circus change is straight across the platform, typically taking less than a minute from getting off one train and onto the other.
*Between the hatched "keep clear" zone next to the barriers and a line on the floor roughly 10 metres further out.
Be aware, though, as you are aiming at the 10.24 Eurostar that the Thameslink isn't every half hour in the morning peak - unless the timetable has been plugged recently, there are some serious gaps at Sutton in the morning peak!
I was going to say that it's a very long walk from the tubes up to the surface at STP.
Lifts are available, but not all are that obvious.I was going to say that it's a very long walk from the tubes up to the surface at STP.
What gaps are you thinking of?
