Essex towns quiz
Sprinter
14 Jun 2005
Walthamstow, London
Below are the names of 13 Essex towns, cut into segments and mixed up. Your task is to put the segments back together in order to make an Essex town name. All segments are used and each segment must only be used ONCE.
For example if there were segments HERT and FORD, this would give you HERTFORD
The segments are:
SAFF HAL EPP LOW TON LING
CLIFF LOU TER DON SOUTH STEAD
HAR DEN TED WAL CHES WEST
END COL STED CLAC ING BRIGHT
SEA MAL RON THAX FEL GHTON
NOTE: Those segments in bold have already been unscrambled
Good Luck. You can answer as few or as many as you want.
Sprinter
14 Jun 2005
Walthamstow, London
The following are correct:
Clac + ton= Clacton
Epp + ing= Epping
Lou + ghton= Loughton
Har + low= Harlow
Saff + ron + Wal + den= Saffron Walden
Walton is not correct, as you used the TON segment twice! (in Clacton and Walton).
Z12XE
30 Sep 2005
FEL+STEAD = Felstead
HAL+STED = Halsted
BRIGHT+LING+SEA = Brightlingsea
WEST+CLIFF = Westcliff (although this one is offically Westcliff-on-Sea)
SOUTH +END = Southend
COL+CHES+TER = Colchester
MAL+DON = Maldon
THAX+TED = Thaxted
