Eurostar spot
starrymarkb
4 Aug 2009
Exeter
Very few spots in London because the first 12 miles are in Tunnel, St Pancras, Stratford International & Rainham are probably your best bets. Dagenham dock might work for trains coming out of the tunnel.
Peter Mugridge
8 Apr 2010
Epsom
You could try the RSPB reserve at Rainham Marshes; the "boardwalk" part of the circumference footpath is extremely close to the flyover section of HS1 although you'll need to plan your angles carefully because of a couple of National Grid lines immediately behind the viaduct...
At least the sunlight will be behind you virtually all day...
