railfan99
On Eurostar recently, my train used the original French line for part of the journey, meaning a slower trip.
Why is this occurring?
How long has this been going on for and when will Eurostar revert to the high speed route all the way?Engineering works.
Shame really, the ride suddenly becoming roller coaster like after you reach speed again after the tunnel feels like part of the experience of going to the Continent. Will be a bit boring if it's a smooth as HS1 now!There has been a lot of track relaying going on over the last few years - LGV Nord is 30 yo after all.
Eurostar quite often uses the classic lines on the continent when there's disruption or engineering.
In the UK it can't, as any diversions would be onto the third-rail network and the trains are no longer fitted with the equipment.
That makes sense for a trip to Paris, certainly. Colleagues used Brussels services on the same day, I have asked.Mine on 1 November 2024 was on the old line from about 1336 to 1440, and passed through Hazebruck and I thought Arras. Apologies if my spelling is incorrect.
Oh, now you're talking. Let me know and I'll go and get my tickets!! Maybe some 50s too as can get speed up a bit? Be rather rateable on load 18 or so!!!So what will be the plan when renewals will be needed on HS1 in UK?. Shove a Cl 37 on the front?
I assume services just won’t run then. There’s really no alternative.So what will be the plan when renewals will be needed on HS1 in UK?. Shove a Cl 37 on the front?
None, the services probably won't run as both the 373 and 374s are uncouplable bar for rescue purposesSo what will be the plan when renewals will be needed on HS1 in UK?. Shove a Cl 37 on the front?
A semi regular occurrence when newThough I agree a cl. 37 hauling a 373 would be fire to see.
Probably to use Ashford/Ebbsfleet and transfer to SE. It might even be the thing that gets them reopened! (Although I hope at least Ashford reopens sooner than HS1 would need renewal).So what will be the plan when renewals will be needed on HS1 in UK?. Shove a Cl 37 on the front?
Are you sure you didn't use the (very short) emergency connector at Lille Europe? Via Armentieres and Saint Omer?Mine on 1 November 2024 was on the old line from about 1336 to 1440, and passed through Hazebruck and I thought Arras. Apologies if my spelling is incorrect.
Last Christmas, when the HS1 tunnel under the thames was flooded, all trains were cancelled all the way, though in principle the train could have run into Ashford (and ran back to the continent empty, as no facilities to handle that many passengers)Probably to use Ashford/Ebbsfleet and transfer to SE. It might even be the thing that gets them reopened! (Although I hope at least Ashford reopens sooner than HS1 would need renewal).
I think you're right that's the most likely option, although I'd point out that HS1 is more practical to close only part at a time depending on the work site as there is space to erect barriers between the open and closed lines. Also, given border control are posted workers at St Pancras, there is zero possibility of operating a departure from Ashford or Ebbsfleet on short notice when they aren't there. For an unplanned closure therefore there would never be any alternatives for trains and passengers would simply be diverted by other modes. This is inevitable.Last Christmas, when the HS1 tunnel under the thames was flooded, all trains were cancelled all the way, though in principle the train could have run into Ashford (and ran back to the continent empty, as no facilities to handle that many passengers)
I suspect that when HS1 has to close for engineering works, there will simply be a day without services
Aren't the Class 374s built to continental loading gauge as well so they wouldn't even fit on normal tracks?I assume services just won’t run then. There’s really no alternative.
IndeedAren't the Class 374s built to continental loading gauge as well so they wouldn't even fit on normal tracks?
Rail replacement bus. The UK way.So what will be the plan when renewals will be needed on HS1 in UK?. Shove a Cl 37 on the front?
What, and open up Ashford International!
Neither. Being 'fully reserved' service, they simply will not advertise or sell tickets for, the day(s) that the renewal will take place, and not operate any trains. Passengers will have to travel on other days, or if the day is critical to their plans, by other modes. Not difficult.
Eurostar also don't offer alternatives when other trains are available. Currently, some of their services to Germany are cancelled and the ones that do run are limited to Aachen or Cologne. Passengers whose train is cancelled or partly cancelled get an e-mail that says you can either rebook to another train (with no extra costs) or get a full refund. They fail to mention what your options are if your train was the last connection of the day or if their next available service is only after 23/12 (e.g. to/from Essen or Düsseldorf). Of course this isn't compatible with current EU legislation but I suspect they prefer to wait until someone challenges them.Pretty sure I've seen that on the ex Thalys routes - no alternative offered.
I don't suppose many people who would normally travel on a high speed train would be that interested in a replacement coach.
If travelling on that day is critical, and all the airline capacity is taken up, then they may well have to avail themselves of the alternative scheduled coach services.Pretty sure I've seen that on the ex Thalys routes - no alternative offered.
