Eurostar
robertbishop
5 Oct 2010
I'm off to Brussels for work in June, and I'd like if possible to travel on both the old (Class 373) and new (e320) trains. When booking, is there a way of knowing which type of train is allocated to which service/diagram?
Seat61.com says that you can tell by the number of coaches - information that can be found after booking. Is there any way of knowing before booking?
Thanks!
Peter Mugridge
8 Apr 2010
Epsom
The 374s do not yet work to Bruxelle in service so you'll get a 373 each way unless things change very quickly.
CalaisFret
13 Jan 2016
you might want to try the e300 if you are have to go to Brussels (e320 interior in a class 373.) Eurostar contact centre may be able to tell you which services these will be running from but it's not possible to tell from the seat map as this is the same for e300/TMST
