Euston overcrowding
DarloRich
Fenny Stratford
There were previously "alongside" ads, there was a fairly unobtrusive TV format ad board at each end of the main departure board.
Yes - but I doubt ( I don't know) they pay as much as the full screen ads. That gap needs to be filled because that is money that cant be spent on the railway.
BTW: I have no problem with the big screens being turned off or changed to running information - simply that I suspect that will mean contract renegotiation and cost impacts.
Also the new screen on the cancer balcony are very helpful.
Dr Hoo
10 Nov 2015
Hope Valley
I don't have a problem with the mezzanine, it keeps retail out of the way of the concourse and isn't an entirely unpleasant place to sit. The steps down by WH Smuggs Reading Room are in the way of entrance/exit flow, though, and could do with being moved.
Can you clarify where the stairs might be moved to, please?
I think it was a slightly poor description of the outside smoking area at the front of the station. I didn't get it at first, but I suppose it's sort of a balcony because it's elevated above street level.
Right. I was wondering about the carcinogenic qualities of the mezzanine.
uglymonkey
10 Aug 2018
I wondered in terms of disruption, Kings Cross on the ECML ( and Thameslink as well ) has Finsbury park not that far away, which is a fairly big station with underground access. It can be used as a temporary terminus and turn around if Kings Cross is "fouled" up or overcrowed. Does Euston have the equivalent ? - a possible "Stop and turn around" point with 10 minutes running of Euston? If Euston was overcrowded could they stop some trains short ??
Steve Harris
11 Dec 2016
ECML
Hmmm.... I think suggesting Finsbury Park can be used as a temporary terminus is stretching things.... do you not remember Christmas 2014 when it was used as a temporary terminus!
It had to be closed due to overcrowding!!!
As for the Euston, the only place where it might be possible to spin some services would be Harrow and Wealdstone were customers could get on the Bakerloo line.
Whatever way you look at it, there isn't anywhere which can be used as a temporary terminus at short notice. As Finsbury Park proved a decade ago, there isn't anywhere with the physical capicity.
The only viable one for IC services is probably Old Oak, i.e. put them onto HS2 sooner than planned. You'd realistically have to keep something open for commuter services - the Bakerloo wouldn't cope.
BRX
20 Oct 2008
That is something posters here overlook. The problem being the "alongside" ads will earn less revenue ( I expect) than full screen adverts. Hopefully someone in government will make up the balance as less ad revenue means less money to spend on the track.
That will be one of the reasons the screens were put in. It is also why the Mezzanine went in: More revenue
I'm not sure why you think the advertising revenue component of decision-making is overlooked. Unless you think that most posters here believe the advertising was just put there for fun.
DarloRich
Fenny Stratford
I am simply saying that the widely applauded action has a consequence that needs to be addressed. I suspect most posters haven't given it a thought. Simply saying the government will make up the difference is not a given.
Old Oak Common will perform that function once HS2 is open.
dosxuk
2 Jan 2011
I wouldn't say for fun, but I would say the impression I get from most posters here is that they think the advertising was put there because some advertisers wanted that wall and NR thought it would be easy money, so they ripped the old departure boards down and gave them the whole wall without any thought to the consequences.
BRX
20 Oct 2008
I'm guessing that like the rest of us, you don't know what the consequence is, and therefore to what extent it needs to be "addressed", because we don't know what the amount of revenue was.
DarloRich
Fenny Stratford
Whilst I don't know the figures involved I am sure they will be decent ones! That funding gap has to be filled or projects somewhere will suffer. The contracts associated with those boards (with JCDecaux ?) will also have to be renegotiated or terminated at cost. That is more money out of the railway at a time of financial constraint.
For completeness: I don't say they shouldn't be turned off just that doing so has a consequence. They were put in to gather more income for the railway to spend and that money will not be available unless it is made up somehow.
Steve Harris
11 Dec 2016
ECML
Hence why I said "some" and not all !! (Even I recognise that you can't dump everything onto the Bakerloo, as you point out it wouldn't cope, hence my reference to what happened at Finsbury Park in 2014).
Euston gets overcrowded now does it not ? So what's the current answer ? Not the answer in 5 years time (when HS2 might be open and running).
DynamicSpirit
12 Apr 2012
SE London
If there's a need for advertising revenue, there are a couple of very nice, but smaller, boards in the middle of the concourse, a couple of which could perhaps be repurposed for advertising once the main boards are put back to their proper use of displaying departure information ;)
Mikey C
11 Feb 2013
The revenue from that advertising screen in Euston is surely tiny in relation to NR's overall budget, and indeed the cost of rebuilding Euston anyway.
Trackman
28 Feb 2013
Lewisham
Someone has put a FOI request about deploying the new boards and if correct procedures were followed etc..
Starmill
18 May 2012
Bolton
Often the other way around. The general public aren't daft, they attempt to ignore advertising if they can get away with it. When it's placed right in front of or immediately in the sightline if information they need to see, however...
For example there aren't advertising panels inside Northern’s trains any more. But there are ads flicking around on the screen that tells you what the next station is.
Finsbury Park was a nightmare mainly because of the overrun rather than because the station was too small. Although of course it absolutely is way too small (even in normal weekday peak operation sometimes...).
takno
I find it weird that people simultaneously create these kinds of FoI requests and rant about NR managers acting like NR managers rather than human beings. The decision was made a year or so ago under a very different government - if somebody had gone on record then turning down the probably-significant revenue they'd have been castigated by the DfT for waste
modernrail
26 Jul 2015
It was an operational decision at a publicly funded railway station. The Government will have been nowhere near the detail of the revenue decision - that will have been down to an NR Manager of dubious decision making ability. As a publicly funded organisation it is of course right that dubious decision making can be identified and called out, and so FoI is an important tool to ensure transparency.
The argument that actions have consequences is also to me a non-point here. Of course NR have made a contractual horlicks of this one and will no doubt have a mess to sort out with the advertising company in question. However, this is not a revenue argument. NR did not need to cover half of the station with a ridiculous wrap around advertising board just because they had moved the actually useful destination boards somewhere else less useful. If that was a valid argument for revenue creation then there are lots of other blank NR surfaces, every inch of which could be covered in far too bright, far too big advertising. They don’t do that because that would be stupid, and would annoy everybody. Just as this decision was stupid and has annoyed everybody.
They have also created guilt by association. If they can make such a big call so badly, how good is the rest of their decision making in how they run the station. They literally approved the erection of a comedy sized advertising board that, I would argue, was never, ever going to be acceptable to normal passengers. That is before you start to bring in the needs of passengers who could be adversely affected medically by something so stupidly massive, dynamic and bright.
I went through Euston this evening and the sign is off. Hopefully this is a turning point in the restoration of sanity in Euston decision making and operational competence.
takno
To be absolutely crystal clear, I welcome the board being turned off, and I'm not opposed to FoI requests. The idea that NR managers have real agency in these situations though is delusional. FoI requests are used by both sides in any argument, and the last government were painfully penny-wise and pound-stupid, and doing idiotic stuff like this ad board was essentially required from public servants.
For a more historical perspective, it may be instructive to look at pictures of Waverley station from the 60s, when the bridge and main building were completely obscured by an absolutely massive advertising board. Had LED displays existed at the time I suspect that the good people fro British Railways would have jumped at the chance to cover every major station in the country with them
modernrail
26 Jul 2015
I would genuinely be interested to know what the chain of decision making was to approve the ‘big board’ - and which levels of NR managers were involved, whether all were Euston station managers or whether it went up to some wider approvals process etc.
Harpo
21 Aug 2024
Newport
I’d not be surprised to find that that those trying to operate Euston station had little or no knowledge of the commercial activities of those pimping it out to tenants and advertisers.
In an organisation of silos, where internal man-marking was often mandated by seniors, I suspect it might not be just the users blind-sided.
185143
3 Mar 2013
Harrow & Wealdstone has been used as a turnback for Pendolinos before during an Easter block IIRC, think it was 2019?
Pretty sure it's only been done once and was a very reduced service (something like 1 Manchester, 1 Brum, 1 Glasgow and maybe a Liverpool each hour?).
Dr Hoo
10 Nov 2015
Hope Valley
At a high level it is worth noting that 'Other Income' is a significant source of revenue. There was even a special section of the Periodic Review 2023, preparing for Control Period 7 (CP7). Although details can be a bit vague in distinguishing between things like roadside advertising and other property/rental income at major stations from retail outlets, I think that I'm right in saying that advertising revenue associated with major stations is expected to increase by 50%, to £209,000,000 in CP7, so not exactly loose change. I doubt that any other source of income for Network Rail was expected to increase so much. Details from PR23 final determination: supporting document – other income .
jfollows
26 Feb 2011
Wilmslow
Only if the empty sets carry on to reverse somewhere else, there is no facility to turn back at Harrow now and - I don’t think - in 2019. But they could reverse in the slow line platforms at Wembley Central.
Since the (Tory) government threw out the plan to build a new integrated Euston (HS2 + NR rebuild) last year, what certainty is there that the NR section will be rebuilt separately and on what timescale?
It takes years to develop plans, find funding and get sign-off from all the stakeholders, which has been the problem all along.
Has NR got a separate plan for its assets in its back pocket somewhere?
31 Dec 2019
uk
Only way to find out what's happening at Euston is by tuning into BBC Parliament on October 30th.
